Question about Swatch Watches
How to set the .beats
Don't have the instruction manual.
I am able to set everything else (hours, minutes, etc.).
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How do you set a popart pop-693ad watch
Ok, it took awhile to remember, but to reset the analog time or the day or anything else, first push the "mode" button which is at the 8:00 position on the side of the watch, 3 times. The first push will bring up the stopwatch, the 2nd push will change the alarm time, the 3rd push will highlight the seconds which on the watch face is at the 6:00 position. Release after the 3rd push and push the "reset" button which is located at the 4:00 position. It will start flashing the hour first. If that is what you need to change, then push the "start" button which is at the 2:00 position. Either keep pushing the start button to set the hour or hold the button in if you have more than a couple of hours to change. When that is done, if you need to change the minutes, push the "reset" button again and the minutes should be highlighted and do the same thing with the "start" button until you have the minutes set where you want. When you are done changing whichever thing needs to be set, including the alarm time, push the "mode" button and everything will stay set. This is for the Pop Art 693 AD watch which if you buy through ebay, it's an awesome watch with dual analog/digital time displays, etc. it comes with no instructions. If all else fails, go to the jewelry counter at a Walmart and hopefully the worker there can help. We found that once with a different watch. I hope this helps everyone!!
Nov 13, 2012 | Watches
How to set a Timex 1440 ports watch WR50M
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Oct 08, 2012 | Timex 1440 Digital Sports Watch - Green
I am trying to set a digital watch, there are 4 buttons 1=light 2=mode 3=start&stop 4=lap reset. I can not find the name brand and I bought it at a second hand store for my grandson. The only name I...
mcdevito75here, I'm sue I can help you set this digital watch,----4 buttons, 1=light, this should be just for the light built into the watch, 2=MODE this is the button you press to set the functions, press this button and see everything flashing 3= Start Stop this button should act as set after you press MODE it should also be to start the lap counter and 4= lap reset this should bring the lap counter back to zero or the seconds tick normally.---- press MODE see everything flashing, then press start stop to set functions, hour, minute etc, press MODE after you have set each function, hour, minute, etc. When done with all functions press mode again to bring the watch back to normal operation.
Jun 23, 2010 | Watches
How to set hour minute seconds,date etc
You can get instructions from the Timex web site "timex.com".
At thebottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 12, 2010 | Timex T2M211 Classics Indiglo Watch for...
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Set time on columbia 100 meter
hold set for 5 seconds, then push mode the hour will flash set the hour buy using the butions to the right top to go up botom to go down,when your have the hour push mode agen then set the minutes the same way, when your done push mode agen then it is done. problem solved.
Apr 28, 2008 | Columbia All Sport Digi Watch l
Adidas watch
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
Dec 24, 2007 | Watches
Casio g-shock watch
http://world.casio.com/wat/download/en/manual/
try for the manual from here.
riz.
Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Watches Logo
27 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
