Question about HP Photosmart C6180 All-In-One InkJet Printer
C6180 unable to find paper jam
I am asked repeatedly to clear the paper jam and reinsert new paper into the tray by my printer. I have checked around the print cartridge, the paper tray, and I even tried to remove the whole paper tray, but nothing seems to work.
  • paul242 Sep 26, 2009
    Hi all,
    I found the problem: I took a mini flashlight, and I saw a crumpled piece of paper in the very back of the unit. I then found an easily opened hatch on the back wall of the unit, and I removed the paper.
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
  • 99 Answers
SOURCE: error code 1517--remove and check cartridge
Solution Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. Step one: Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00107909). (in English). Moving the carriage
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the all-in-one. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
  4. Verify that the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
  7. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Step two: Ensure correct installation of the front panel overlay If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: 12If the front panel overlay is already installed, proceed to the next step.
  1. Insert the two tabs of the bezel into the top slots on the unit. Figure 1: Inserting the tabs c00303994.gif
  2. Tilt the bezel down and press firmly. Verify that the tabs lock into position and that the cover is even with the edges of the unit. Figure 2: Locking the tabs c00303995.gif
  3. Try the print job again to see if this step resolved the issue.
Step three: Plug the product directly into a wall outlet Verify that the product is properly connected to a suitable power source by following the instructions below.
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the power cable from the back of the all-in-one.
  3. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Plug the power cable into the back of the all-in-one.
  5. Try the print job again to see if this step resolved the issue.
      NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Posted on Feb 09, 2008
  • 300 Answers
SOURCE: After clearing a paper jam,
One of the paper flags is either stuck down or broken (from the area of the jam)
Posted on May 17, 2008
SOURCE: photo tray doesn't work
hp f 4235
Posted on Dec 25, 2008
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
Posted on Apr 20, 2009
How do I remove the paper try on a HP C6180 printer
Support for Printer Technician Visit and Read more help..
HP Printer Support
Thanks,
Aug 07, 2014 | HP Photosmart C6180 All-In-One InkJet...
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
The printer is showing that paper jam but there is no paper in the printer.
Open the tray in the front and remove the toner cartridge, open the back panel and make sure that is is clear as well, and then slide open and closed the paper tray. Now reinsert the toner.
For some reason when this thing jams, if there isn't an actual paper jam then you have to check every panel before it will let you move on. You don't even have to remove any paper half the time...just open and close each panel and remove-reinsert the toner.
May 12, 2010 | Brother MFC-8220 Fax
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
My brand new X5340 printer shows there is a paper jam but there isn't one. The one and only sheet it has printed was the test page. Since then, I have been unable to get rid of the "clear paper jam"...
hi
follow these steps
1.checked for and remove any obstructionsfrom paper feed tray.
2.tilt and shake printer..checked for any rattling noise..checked for any foreign objects inside printer obstructing the paper flow.
3.Take a sheet of paper ..fold it length wise 3-4 times to make it a thick.insert this into paper feed tray...move it left and right a couple of times..unplug power cable and replug it after 10 seconds...try printing ...if it does not work,,,,contact tech support 1-800-332-4120...ur printer is brand new and under warranty cover,,,they would replace it for u.
goodluck:))))
Jan 23, 2009 | Lexmark X5150 All-In-One InkJet Printer
Photo tray output problem
I fixed it just now and easiest, following the step below:
1) Can you see the blue thing between the paper tray and the printing tray? That's the Output Tray! Just press it back in as much as u could
(but don't break it). Then you trying print (testing), they might have a paper jam but its normal. After the jam, they will tell to dismantle the jammed paper at the back.
2) Shut down (or restart) your printer (unplug the power switch or it won't work). Plug it in again and then just simply its done!
3) If it won't work, repeat the previous step again... Good Luck ;)
Jul 29, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
