Question about GE 30 in. JGP337 Gas Cooktop
Clicking sound coming from cooktop. Already replaced module since all 4 would click. Removed an electrode and clicking moves to another electrode. Also when the burners are removed the cooktop does not click anymore even with all the electrodes in place.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Aug 30, 2010
One of burners can not ignite only having clicking sound.
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Sep 10, 2011 | Jenn-Air JGC8430 Gas Cooktop
Igniter works, but the clicking doesn't stop
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Gene
Aug 11, 2011 | DCS 36 in. CP-364GD Gas Cooktop
My front left ignitor/electrode is continually igniting on its own. How do I get it to stop?
Somethings when we clean the cooktop with a damp rag especially around the knobs moisture can get onto the burner switches. When this happens it creates a short and spark the electrodes. Try to unplug the unit for 24hrs. I have had so many just dry out and never had a problem. If you try this and still get the clicking change out the wire harness part#WB18T10339. Its a series of switches that sit on top of each burner and connected to the spark module. I would recommend changing out the spark module part#WB13T10046. Both of the parts are only around $20-$30 a piece and you will have your cooktop running like new.
Please look at item numbers 323,318 on the picture thats what needs to be changed out national_a_r.png
Please rate me a "4" if I helped you. Have a super day!
Dec 14, 2010 | GE 30 in. JGP328 Gas Cooktop
I can't get the electric ignition to stop clicking. I'm not sure this is the right model, but it looked the closest to my cooktop
Hi- most likely the spark module is bad. Sometimes a burner swith gets stuck as well. Unplug the unit, the plug should be inside the cabinet. Take off the knobs and see if you see any obstructions and see if the knob posts move freely in and out (push to turn). Probably need to get a Tech out to look at it. If it is clicking even when the burners are off you can just leave it unplugged and light with a match to use it. If it is only clicking when you have the burners on check to be sure all the burner bases and caps are assembled correctly and seated, sometimes the electrode will continue to click if the burners are assembled wrong or are wet. Hope this helps a little. Good Luck.
Sep 24, 2010 | Maytag MGC7430WS Stainless Steel Gas...
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Where is the spark module for the GE Monogram Gas Cooktop Model ZGU375NSD1SS located? All 5 burners work, but there is a constant click, click, clicking that sounds while they are in use... :( So I already...
Hello, refer to the next web page: partselect.com/. then select the part blow out for cooktop box components, I believe item number 28 is what you're looking for. Hope this helped.
Jun 28, 2010 | Cooktops
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
My ignition will not stop clicking
hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
GE gas stove top igniters won't stop clicking
My wife just called me with the same problem - all 4 starters are clicking repeatedly - which started while the range was being cleaned.
From a Google search, this is what I found. Don't know if it will solve our issues, though wanted to share as it sounds like we may all be suffering from dirty starters (electrodes).
My surface burners keep "clicking" even after the burner is lit. There are a few things to check for.
And, to check the model number, look at the various places pointed to in the upper left of this diagram. http://www.applianceaid.com/newpics/range-model2.JPG
Oct 18, 2008 | GE Profile JGP636 Gas Cooktop
Romvoing the top of my Whirlpool Cooktop
first thing is the spark module(ignitor-- your referring to) is probably good and your electrodes are damaged. more then likely the problem. when you turn on one burner they should all spark( 1 module controls all 5 electrodes) so lets check that, first. when you turn on any/all burners do you at least hear clicking??. theres a switch under each **** that turns on the spark(erhaps one of them is bad. think of the electrodes as spark plugs on a car, they spark the same way, ck to see that they are clean(free from rust and carbon build up).using emory cloth or a woman's finger nail file try "sanding" down to a shiny surface the very tip of the electrode protruding out of the burner head.look for cracks in the porcelin housing around the electrodes this will lead to miss fires of the electrodes
Mar 11, 2008 | Cooktops
GE 30 in. JGP337 Gas Cooktop Logo
545 people viewed this question
Top GE Cooktops Experts
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
