Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Mfc665cw is offline, how do i get it to go online.
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Printer offline wont print cant get back online
Step 1:
b. Click Printer.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
Is it possible that you are offline I mean your computer is off but shows you online to your freinds ?
oovoo had issue where online contacts were shown as offline. I am sure it is possible that a bug might show offline contact as online.
Jun 07, 2012 | ooVoo
My printer says its offline how do I reconnect? I've already done a complete power off and it's still offline.
hi
just folow the step
Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Jul 07, 2010 | HP Deskjet 6940 InkJet Printer
I have windowsvista and plugged my hp pcs1210 into my laptop with a usb and my printer box states my printer is offline
Reference: http://www.ehow.com/how_4796279_change-printer-offline-online.html
There's a small chance this might be your fix.
Hope this helps!
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online | eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz0vK6bYiB5
    May 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Printer Offline Message
    If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
    1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
    2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
    3) Set the printer online if it is showing offline.
    4) Now right click the printer and select "Use Printer Online".
    5) The display should change to ready.
    Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
    Jan 07, 2010 | Epson Aculaser C1100 Printer
    Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
    Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
    Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
    Brother mfc665cw empty cartidges
    You can't fool Mother Brother, all carts are used for black too.
    Feb 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
    Brother mfc 665cw connection error
    I have a MFC665CW connected wirelessly to a router and a pc connected by ethernet to the router, with a broadband satellite receiver connected to the WAN port of the router (plan to add another PC to the network soon, so have set up the network in advance). I had trouble with the brother status montior flashing 'Ready' then 'Offline' all the time, when I knew the printer was always connected to the network. I had set up the DHCP stuff on the router to allocate IP addresses to everything that connects to the network, like you are supposed to. I updated drivers and firmware, but the problem continued.
    When I checked the router status log I saw that one MAC address in the network was making a DHCP request every 5 minutes (i.e. it was asking the router to allocate it an IP address at regular intervals). Every time the router answered that request it made the Brother status monitor go 'offline'. The MAC address was my broadband modem. I fixed the issue by setting the router to allocate a static IP address to the MAC id for my broadband modem (in the DHCP setup section in the router's admin interface). That stopped the dynamic IP address requests from the broadband modem and the Brother status monitor works fine now. I also set static IP adresses for the printer and PC to be on the safe side, although I don't think that matters.
    So, check your network log and look for a MAC id that makes regular DHCP requests and then set a static IP address for it. Hope this helps you guys too.
    Mar 30, 2008 | Brother Multi-Function Center MFC-665CW...
    Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
    122 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
