Question about Jazz JDC27 Digital Camera
I got this camera a while back and have lost the disk that came with it. My computer crashed and had to be replaced but I can no longer use the camera because I have no driver for it Is there a way I can down load one?
Flashing folder when i turn on mac
Your hard drive may have crashed or it's settings have changed so it is no longer recognized as a startup (boot) drive. Try starting from your original operating system CD. (or borrow one). Press the C button at power up to force your computer to start from the CD.
Once started, don't install the operating system. Go to the pull down menu's and select Disk Utility. If Disk Utility sees your hard drive, select it and run the repair disk program. If it doesn't see it, your hard drive has likely crashed. You will have to replace it, install a new copy of the operating system, and likely have lost all your data and documents. This is where I would start.
Mar 08, 2014 | Apple MacBook Pro Laptop Computer with...
My computer crashed,and my canon camera info was lost, problem is I have lost the CD to re-install so I can not download photos from my camera, help! (Power Shot SD850 lS)
This type of question comes up several times a day here at Fixya. Unfortunately, Canon does not offer replacement software disks. You can search eBay for a replacement disk, but would instead recommend that you please see this article, as it describes the use of an inexpensive card reader as a much easier, faster, and less error prone way to download your photos and videos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue.
Dec 23, 2009 | Canon Cameras
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
Have lost cd, computer crashed. no way to download
Here is Canon's download page for your model. You can download the software you need and all the other documents they have available.
May 21, 2009 | Canon PowerShot A640 Digital Camera
Lost installation disk for samsung digimax s500
www.samsungcamera.com
click on "support & download" at the top of the screen. Then click on "download" in the sub menu.
Digimax s500 is on page 8 and number 87.
Mar 06, 2009 | Sakar Digital Concepts VGA Micro Digital...
Lost disk
I spent a little time trying to find the installation manual on line but failed.
What you can try:
- Attach the camera to your system
- Reboot
If you are lucky, Windows will 'find' the new 'device' and install a basic driver that will let you see the memory of the camera in "My Computer" as a disk drive.
If it works, you will be able to handle the files as you would any others.
In some cameras, if you open the 'drive' (your memory card), you may see only a folder.
Opening that one, there might be another folder.
Repeating that one more time should get you your image files.
Sep 02, 2008 | Sakar Kidz Cam Digital Camera
Canon Powershot G7 digital camera
A friend suggested I uninstall the digital camera solution disk and then reinstall it. I did so and although my computer seemed to crash once it was restarted after turning it off and back on and getting a blue screen from microsoft stating I had to start it manually everything worked out. I am so thankful. I got about 100 pictures downloaded and stored into the appropriate album. Thank you for your concern.
Jul 09, 2008 | Canon PowerShot G7 Digital Camera
Format problem
the first thing you should do is get a new USB lead.
while your waiting for your new lead:
1)find out if your laptop crashes with that card, or with any cards/devices.
2)try putting the card into another computer.
3) if you have a compatable printer- put your card in there and try to print your photos.
(if you want them on your laptop- scan them in)
if the other devices or cards work with your laptop- then it might be a dodgy card
if no cards work, or if other devices cause crashes- it might be a problem with you laptop (like a faulty card reader)
if the card works in a different computer- then it might be a problem with your laptop
if the card dosent work in a different computer- it might be a dodgy card.
May 09, 2008 | Olympus FE-190 Digital Camera
Jazz JDC27 Digital Camera Logo
21 people viewed this question
Top Jazz Cameras Experts
Pavel Pranovich
Pavel Pranovich
Are you a Jazz Camera Expert? Answer questions, earn points and help others
