Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Trouble Shooting and Routine Maintenance
Hi
My Brothers 240c Printer keeps saying (troubleshooting and routine maintenance). Go to chapter in users guide. "Print Unable".
How do I clear up this matter?
Pat
SOURCE: user's guide- trouble shooting and routine maintenance
printer will not print referring me to the trouble shooting and maintenance chapter in the manual which I can't find......I have a Brothers MFC-420cn CAN YOU HELP ME......
Posted on Feb 05, 2008
  • 352 Answers
SOURCE: The printer simply says, "Unable to print. See troubleshooting and Routine Maintenance guide chapter in User's manuel." Thanks.
Hi Bang, give this a shot,
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 14, 2008
  • 742 Answers
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Posted on Jul 11, 2009
eliza_syafik
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
clean unable 46,see troubleshooting and routine maintenance chapter in user guide.Plase help me to splve this problem.
Posted on Aug 12, 2009
anantakumarj
  • 330 Answers
SOURCE: troubleshooting and routine maintenance chapter
goes through below link and down the user guide .....
http://welcome.solutions.brother.com/BSC/public/as/as_ot/en/model_top/colormfc/dcp165c_all.html?reg=as&c=as_ot&lang=en&prod=dcp165c_all
Posted on Dec 31, 2009
Drum error,see trouble shooting routine maintenance and chapter in user's guide
Jan 27, 2014 | Ricoh SP1200 Drum Unit
Dcp-165c clean unable trouble shooting and routine maintenance chapter in user's guide 46
for non fax models ie I have DCP 165C you say press ...... press up arrow four times then press 8 then 0 etc ... but I have no numbers to press!
Jul 15, 2012 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Its says. see trouble shouting and routine maintence.chapter. in users guide,.but theres nothing there in the book
Hi there. . . okay . . . Follow this step 1.) Unplug your printer. 2.) Plug your printer again while holding the menu button 15 sec. 3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK 4.) then numbers appear looks like this ###:### ###:###. 5.) now push the MONO button until the purge:#### appears on the LCD 6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok 7.) - switch off the printer ,switch it on - ready to print - CHEERS! email me if I helped you. . ryuuzaki182@gmail.com
Aug 29, 2009 | Brother DCP 130C All-In-One InkJet Printer
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
106 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
