Question about Husqvarna Garden
Sit on mower as soon as i move handle to rotate the blades the engine cuts out
  • 143 Answers
It could be the grassbox switch, check that the grassbox is closing tight. Or the switch could be faulty, also check the seat switch. Stephen.
Posted on Sep 29, 2009
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
How do i remove the cutting blade from a morrison 500 reel mower
Disconnect spark plug wire. Turn on side. Block blade from moving using a block of wood. Loosen blade blot with appropate wrench or hindge handle(breaker bar) and socket.
Oct 19, 2014 | Garden
Pto will not disengage
first unplug the switch and see if it still operate then disconnect the spark plugs then turn the blades threw the discharge opening and see if the engine rotates when moving the blades this will tell you if the clutch is stuck then connect the spark plug wires back on and next to the engine base you will find a 2 wire connector that feeds the clutch power and ground unplug that connector and start the mower see if the blades turn this will tell you if you have a mechanical failure if it does not operate with the wires unplugged its a electrical
Jun 13, 2012 | Oregon Scientific Electric PTO Clutch for...
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Blade wont start
Check the linkage on your hydro drive.Follow shift lever from handle to trans axle and see if linkage is ok. :)
Sep 07, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Swisher lawnmower wont mow
Yes It would. The belt doesn't just wear it slackens also. It will probably turn the blades when not under load but as soon at it attempts to cut grass there is not enough grip.
Replace the belts first and it should be fine.
Regards
Marc
Apr 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
