Question about Garden
Briggs and stratton 125K02-0131-E1 is leaking gas from around the air filter. I have looked at the hoses and they seem to be fine. I seen where to bang on the carborator to undo the foat, have tried that, still leaking and will not fire
    Problem Solver:
  • 23 Answers
Float is either faulty or sticking very bad, manualy take it out and clean it make sure it moves freely
Posted on Sep 26, 2009
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How do I fix a stuck float on briggs and stratton 19.5 twin
take the float out and test iff the pin holding it in is free by holding the with pliers and moving the float up and down once back in the float should lift up and down free'ly iff not the pin needs to come out of the float and free'd up [sand with fine sand paper or polly-pad or steelo ]
Jun 05, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Gas leak
sounds like the float needle valve is stuck open or it got lost as you were putting it back together. take onother look at it.
Dec 23, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard twin 303447 drops a cylinder when hot under load have to have choke on to keep it going,have cleaned carby and tank plus checked compression and spark
there is hose coming from your valve cover to pump. check it for cracks. one of your gaskets at the air filter housing to carb or carb to black block or block to intake maybe leaking. fuel shut off solenoid could be going bad. choke cable adjustment. there is crank case breather under air filter housing with a s shaped hose coming from it to air filter housing make sure it is not loose. i have an engine at work that did =the same thing. i work at a golf course. i am the mechanic. i changed the hose from valve cover to pump and it cured that problem
Nov 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Motor stops after heated up
Try and blow out the air finns with a air hose. and just blow all around it so it can get air to threw the air finns. do it while its cool and you can use a garden hose. Don't go crazy and hit the fuel tank air filter no more than you have to. I use air first than hose, Then air once more. let it set about two hours and fire it up.
I hope this will be of some help.
Sawdust
Aug 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
22hp Briggs problem. Loading up, runs
Try checking the prefilter on your air filter. I had a similer problem and mine prefilter was completly covered in dirt. I changed the air filter and it solved my problem. Also make sure the air intakes are not partially clogged with dirt or other stuff.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Intek V...
20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Jun 24, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
235 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
