Question about Remington MB-300 Beard Trimmer
I opened up the sideburn trimmer and all the pieces came flying out. How do I put it back together?
Same problem, does anyone know how to put it back together?
Posted on Mar 07, 2010
HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Nov 10, 2011 | Wahl 9854400 Hair Trimmer
CS26, couple of months old. Was using one day, stopped to get a drink came back to start and it wouldn't, rope pulled very easily and didn't sound like it was turning the engine. Opened it up and...
i was given one of these trimmers thats almost new but missing a bunch of parts so im seeking one that owner declares as 'junk'. ill buy and pay cash. locked up okay, blown engine ok, just need handle and body parts with aircleaner assly. anyone got one to sell me? seven06 three22 fourthree79. call mark, regards!
Jul 10, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
Having trouble putting all the pieces back together in the hand grip throttle assembly for a Stihl HL 100 Hedge trimmer
hi carl... there are several HL100 models. go to this link http://www.stihlusa.com/productselector/pruner_and_trimmer_selector.html
select your trimmer and then you can access the parts diagrams which will show you exactly how to reassemble. Joe
Jun 03, 2011 | Garden
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Remington Titanium R-450: sideburn trimmer parts fell out. How do they fit back together?
Remington Titanium R-450 - I have one of these that I got on the cheap. The rechargeable batteries died and the thing would not rev up. Batteries need to be soldered in - I opened it up and cut out the 2 cheap nicads and it now runs like new - just not cordless.
Oct 31, 2010 | Remington Health & Beauty
Can I replace the trimmer blades (not the shaver heads) on my Philips 8175XL? I use them all the time and they are wearing out. Where do I get them and how do I install them?
You will find a replacement trimmer at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-sideburn-trimmer-p-388.html
See disassembly video tutorial at shaveroutlet.com using the link below. You will not have to disassemble as far as the video shows. Just remove the back cover and the trimmer can be 'disjointed' from the cover
http://www.shaveroutlet.com/philips_norelco_shaver_disassembly
Oct 27, 2010 | Philips Norelco 8175XL Electric Shaver
Sideburn cutter part needs to be put back on. It became loose and now has fallen out. I could fix this myself if I knew how to open shaver.
if the sideburn cutter has come off, it is because it is broken. You will need to replace it. You will find the item at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-activator-body-housing-with-trimmer-select-models-p-829.html
For instructional video on disassembling the shaver, also see shaveroutlet.com tutorial here:
http://shaveroutlet.com/video_tutorials
Oct 08, 2010 | Braun 8585 Electric Shaver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
Sideburn trimmer does not cut anymore but still makes noise. trimmer blade does not move.
It is pretty common for the trimmer to get jammed up with hair particles and skin oils which can prevent the blade from moving.
Try running the blades of the trimmer in a shallow dish of rubbing alcohol. Then clean the blades vigorously with an old toothbrush or similar. If the blades still does not move try using the tip of a small flat screwdriver or similar object to push and advance the moveable blade. Repeat running in alcohol and brush clean
If this doesnt work, you will probably need a new trimmer
Apr 15, 2010 | Braun 360° Complete 8985 Electric Shaver
Remington MB-300 Beard Trimmer Logo
615 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
