Computer monitor screen goes black after 10 - 15
Computer monitor screen goes black after 20- 30 minutes and computer is still on.....sometimes to power it off i have to take out the battery.
any solutions as to what is the problem and how i can fix this?
This could be due to the power management settings in your notebook. I suspect that the notebook is entering either in to sleep or the screen saver is set. Check if the issue persists, if these are disabled.....
Posted on Sep 28, 2009
Testimonial: "Thanks alot....i will inform u if the problem persists...thanks again"
  • 30 Answers
Go and check the power setting in the control panel. it may be set in there
Posted on Sep 26, 2009
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
15 inch lcd monitor Benq Model Q5T3 has a blank screen has power but screen just black. Can let it sit for a while and sometimes it will stay on for a few minutes but goes black again Thanks
It could either be a driver issue on your system, or a problem with your video card. Turn off the computer, open the case, remove the video card, re-seat it in the slot securely, close up the system and power it back on. If the problem still happens, update the display adapter driver, if it still happens, try a different video card or monitor. You could even test your monitor by plugging it into a system that you know doesn't have this issue.
Feb 22, 2010 | BenQ Computers & Internet
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
Monitor goes blank after 5-10 minutes
You may have a compatibility issue with your monitor. You computer may not be putting out enough power to support your monitor. Check your users manual on your monitor for output requirements. If the monitor's manual has a number to call, call the manufacturer to see if there are any compatibility problems between your computer and your monitor and calling the people who built your computer as well. Get as many scenarios as you can to find a solution. Hoped this helped.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Black monitor
if you are the technician open you monitor theres something loose wire in horizontal or loose solder
Jul 16, 2008 | Star Logic 17" LCD Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
