Question about Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone
My Samsung RS267LBBP side by side has low water preasure at the dispensor after only three weeks after changing the filter. I've changed it three times with the same result. Also, I've noticed the ice volume and size is low.
  • 725 Answers
With samsung refers the control board and ice maker have be updated Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Posted on Sep 26, 2009
Samsung side by side fridge/freezer ice and water is not working after filter change
If your water and ice maker are not working, you may not have turned your water valve back on. If your water valve is turned on, try rotating your water filter further so that it completely locks as it may not be installed all the way. Once it is completely installed, press the "water" button for approximately three seconds until it turns blue. If this does not solve the problem, you may have a bad filter, here is a replacement filter that you can purchase to install into your refrigerator: http://www.freshwatersystems.com/p-3658-swift-green-sgf-dsb30-compatible-samsung-da29-00003b-refrigerator-filter.aspx
Jun 23, 2013 | Samsung RSG257AARS (241 cu ft) Side by...
No water in water dispensor
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
Feb 21, 2012 | LG LRBC22544 Bottom Freezer Refrigerator
My GE Profile side by side refrigerator ice dispensor and water dispensor has quit working. The appliance is less than 4 years old. Wanda
The common connection between the two starts at the water fill valve. I have found also that the filter (water) if clogged, will prevent water flow to both. Change the filter first, cheapest and eaisest.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I changed the filter for the water dispenser and after purging the water for awhile, the dispenser stopped working. What needs to be done to get the water dispenser to work again
Put the old filter back on , if water was fine . You never change filter just because a light comes on telling you to . The change filter light comes on after time or usage of dispensor .( Good way for manufacturers to make extra money ) . Change the filter only when water flow slows from dispensor .
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
FILTER LEAKS!
go to the hardware store or even a home depot or lowes and get some plumbers pipe dope........a small tube will be plenty. remove the filter and dope up the areas where the two components hook together. it is magical.
May 20, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Every two weeks or so, the water dispensor on door fails
your frezzing line u should never have it set at the highest
Mar 17, 2009 | Samsung SRS20DTD Side by Side Refrigerator
Water filter on refrigerator not working. Samsung
This link will take you to the Samsung support site. There you can find the instructions for replacing the filter....if the filter is not properly aligned, the water bypasses the filter
Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
276 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
