Question about Dishwashers
Won't wash dishes
I can't get the machine to wash my dishes.Only the Pots and Pans Cycle will light up, but when you press start it goes to the drain cycle. There isn't any water to drain.
    Brigadier General:
  • 4,088 Answers
Interrupt the power to the unit by flipping the appropriate breaker off in the house electrical panel for several minutes, then back on. If this doesn't help, then likely the control module is in trouble and needs to be replaced.
Posted on Sep 26, 2009
Wy is top rack not washing
top rack is for small plates & cups not pots & pans as they may obstruct the rotating of the sprayer & foul the water from getting to all the items
Aug 31, 2014 | Bosch Dishwashers
Tip
Tips For Dishwasher for its safety and getting dishes cleanest
A) If your household is small, try gradullay accumulating a full load of dishes and rinsing as you go, instead of stacking dirty dishes in the dishwasher.
B) Cleaners and some elbow grease will always get pots and pans cleaner then the pots and pans cycle on the dishwasher.
C) Good crystal and china should be hand washed and not placed in the dishwasher since the detergents and jostling can damage them quite easily.
D)It can take several hours for dishes to dry when using the no-heat dry option the dishwasher. Try propping the door open to speed the drying process.
on Dec 14, 2009 | Dishwashers
Whirlpool du1055xtss3 not working
I dont know if this indicates a malfunction or not. One user manual may cover several years while many modifications can take place. Ask yourself if any other part of the process can contribute to this. You have electricity to the control board or it will not flash these display indicators.
Is the water on?
Is the waterline kinked under or behind the machine?
Is it connected to hot water? A heater raises the hot water quickly but cold water takes alot longer to reach operating temp. Since the hottest program id pots and pans, this may indicate the heater is bad but since you were able to change the display to pp and normal I think you entered into a controls sequence that technicians can do to make changes to some parameters like temperature setting or water hardness. See if you can get a whirlpool tech to break the grip on his service manual and send you a page by email. Good luck.
Apr 23, 2013 | Dishwashers
Model 664.15732000. The Normal Wash light on control panel will not light up however the Pots and Pans light will. I ran the cancel/drain cycle and re-tried. See my video. Could if be the fuse in the
Hi there, can you put it through the pots and pans wash cycle , see if it works with that first ?
also the drainage pipe might be blocked making the normal cycles unusable.
you might need to get in a plumber or somebody that can unblock a pipe.
Hope this helps .
Dec 29, 2012 | Dishwashers
Manual for hotpoint how to work it
  • Load the appliance with dirty dishes, placing soiled pots and pans on the lower rack where they will be subjected to the most vigorous cleaning. Glassware and dishwasher-safe plastics should go on the top rack. It is not necessary to rinse dishes before loading them in the Hotpoint appliance, unless the dishes have been sitting for awhile and the food particles have dried.
  • Fill the detergent compartment with your preferred brand of dishwashing detergent, and add glass rinse solution to the rinse reservoir on the inside of the door if your model is equipped with one, then close the door to lock in place.
  • Select the cycle you wish to use and press the button. For pots and pans, use the heavy-duty cycle. Normal wash is fine for dishes and utensils.
  • Save on your energy bill by running the dishwasher only when it is full and by allowing the dishes to air dry instead of using the heat dry function on the appliance.
  • Oct 10, 2010 | Dishwashers
    Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
    The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
    The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
    the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
    Press and hold the Start/Stop button while turning the dishwasher on. Release the
    Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
    Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
    Fault codes
    F00 Pots & Pans Lit
    F01 Sani Wash Lit
    F02 Normal Plus Lit
    F03 Normal Lit
    F04 Economy Lit
    F05 Rinse & Hold Lit
    F06 Pots & Pans Lit
    F07 Sani Wash Lit
    F08 Normal Plus Lit
    F09 Normal Lit Flashing
    Sep 19, 2009 | Miele G880 Dishwasher
    Kenmore dish washer lights up but will not start wash cycle.
    turn off your dishwasher then try it again ok
    Feb 27, 2009 | Kenmore Dishwashers
    The washing cycle takes 2 hours to complete
    Make sure the sani cycle is not selected, or pots and pans, also with the dry cycle most will take about 2 hours, if your dishes are not that dirty use the short cycle. Be sure your water is at least 130 F. Run hot water at faucet before starting the machine.
    Feb 27, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
    Kenmore Ultra Wash Dishwasher Problem
    there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
    Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
    Dishwashers Logo
    54 people viewed this question
    Top Dishwashers Experts
