Question about Proform Exercise & Fitness
580x installed new motor controller.LED on board not coming on
  • 40 Answers
Odds are wiring isn't connected right, or the power reset switch is still off, give that a shot.
Posted on Sep 29, 2009
Pdoblem witn proform xp680 treadmill. Incline, decline works, when u start treadmill it runs for a second then shuts off and power goes out then comes back on and beeps twice
Hi sir
1) Please open the covert where the main motor is, disconnect
the connector from the Incline motor.
2) Turn On the treadmill, and see what happen.
3) If the problem does Not appear , is indication the controller motor board is defective.
Since the controller motor board has 3 power supply: 1) Console 2) Main Motor 3) Incline Motor.
LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
celular+WhatsApp:+50588611441
Mar 15, 2018 | Proform Exercise & Fitness
I have a proform 580x treadmill. When plugged in the lights light up, the incline works but selecting a speed does nothing.The walk belt will not move. I removed the cover and checked the motor isn't...
However you must be sure the control board is o.k, since the main motor can NOT be repair only Replace.
Test the voltage DC at terminal at Motor 0Vdc-120Vdc max speed.
Blessing.
cell+whatsAPP:+50588611441
Dec 10, 2017 | Proform Exercise & Fitness
Nordic Track C2255 no power to the console and the fan is running unable to turn of the fan, checked all the wires on the control board and the LED is fixed red.
This is a situation the controller board motor is Faulty.
They controlled the console CPU BOARD. with 8-12VdC
For CMOS Circuit.,this board has 3 control power supply Some IGTB is faulty: 1) Main motor 2) Elevation motor 3) Console Control
HOwever tight the connector coming from controller board motor to the Console very well, and clean it.
Otherwise replace the Controller board motor.
Blessing.
https://www.youtube.com/watch?v=p6PkBZrh4KM
Nov 17, 2017 | Nordic Track Exercise & Fitness
50" proscan led tv new main board but still same issue....
Check whether the control voltage comes to the inverter section cirlcuit at its power board; from the main board. There is a control voltage that controls the light intensity; as well as start, of the inverter section circuit at the main power regulator [SMPS]. It should come from the main board. It this voltage is absent, the main board is faulty. Check whether it is present or not. It will be best to contact any service technician in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 02, 2015 | Proscan Televison & Video
Rheem heat pump not coming on in heat mode. Control board has two LED lights # 1 solid, #2 blinking. What does this mean?
Usually wen the led lights are blinking it means there is a problem. If you look on the door or the cover there should be a code that tells you what the blinking represents.
Example - one blink per second - compressor, two blinks - fan motor, etc. The other thing you can do is look up the model number on line for the installation manual and it should have all the info you need.
Jan 08, 2015 | Ruud Defrost Control Board 47-102684-08...
How much is it for a new motor control board and a new pump each?
A reconditioned motor controller board is cheaper than a new one.
First six digits under the bar code on the yellow label
is the part number for the motor controller board
The Pump you will have to buy new. Sorry
Jan 05, 2015 | Fisher Paykel Fisher & Paykel AquaSmart...
Try to program and it comes error L5
PAGE 63-64 in link Describe "LS" error.
7
Belts stop turning and "err
LS" or "err OS" is displayed
Calibration
Re-calibrate machine. (See Calibration Procedures, Pg 26)
SPEED
SENSOR
1. Cycle power off and on
2. Put the machine in calibration mode (see Calibration
procedures, Pg 26) but do not start the calibration routine.
3. Remove right rear base plastic cover to allow access to
LED board. Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board. LED may
be lit or unlit.
5. Manually advance the treadle with your foot, and check
if LED D is blinking.
6. If LED D is not blinking, then the speed sensor is not sup
plying a signal. Check that the speed sensor is connected
securely to P1 on the motor controller. If sensor is con
nected and LED D still does not flash replace sensor.
I/O cables
If LED D is flashing when the belts are turning but err LS
or OS persists, check for signs of visible damage to any of
the three I/O calbes and connections. If no visible damage
check continuity using a multi-meter. If a multi-meter is
not available replace all three cables.
Electronics
If all I/O cables are functioning properly, LED D indicates
speed sensor is functioning, and err LS or OS persists
problem is in either the upper electronics board or the
motor controller board. With machine on check LED A
on the controller board. If it is dimly lit replace upper
electronics (000-4430). If it is not lit at all replace motor
controller.
http://download.nautilus.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
Jun 04, 2014 | Bowflex Treadclimber TC5300
I have a carrier furnace the control board keeps coming up with differ t led coxes ifiI reset it it works a couple times then flashes a new code had four different codes come up so far 21 22 31 34
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 05, 2014 | Heating & Cooling
No power to ac indoor fan motor
sounds like you might have a bad control board. try putting a jumper wire on the control board low voltage terminals R and G your fan should come on and run if you have 120v power to fan motor. double check that you do have 120 leaving board and going to motor. if no 120 bad board if you do have 120 bad motor. if it is the board it likely has a bad blower relay which is common in amana models and goodman equipment.
Sep 13, 2009 | Amana Heating & Cooling
Exercise & Fitness Logo
61 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
