Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Murray riding mower the blades will not engage
  • Chuck
    Chuck May 11, 2010
    THIS IS LISTED AS A CRAFTSMAN PROBLEM BUT YOU ARE ASKING ABOUT A MURRAY, WHICH IS IT AND WHAT MODEL NUMBER ARE YOU TALKING ABOUT?
  • ttd_7
    ttd_7 Sep 03, 2012
    Murray model 40508x92D, they stop immediately
  • 472 Answers
Sounds like the cabel it broke
Posted on Oct 01, 2009
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
I have a 91Murray 42inch riding mower need proper size belt to run blade,a blade belt
Contact a local auto parts store, a full service one, bring in the old belt and they can match it.
Jun 23, 2016 | Murray Garden
I have a 17.5 Murray riding lawn mower engine runs well when I engage the blades it spits and sputters and starts backfiring what could be the problem
Sounds like bad fuel....runs fine when not under stress but poops out under pressure. Drain fuel and refill with new mix if it's a 50/50 gas-oil blend.
Apr 26, 2016 | Murray Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
I have a problem with the safety switches on my riding lawn mower
e841a1bd-a315-49bb-ae7c-9ba2aedccbb6.gifCheck this diagram. It is most likely the deck switch. as this is a safety switch i would recommend replacing it instead of bypassing it.
Jan 13, 2014 | Murray Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Jul 31, 2013 | Garden
Safety switch located
Micro switches will just stop the engine if the blades are engaged and the operator leaves the seat, or will stop the engine cranking if the blades are engaged, it will not stop the blades from engaging.
Sep 06, 2012 | Murray Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
Hi, I have an older Murray ride on mower, small
Sounds like you have some sort of seize up problem in your deck assembly. Have someone help you with this check, start your engine, engage the blade or blades, and have someone watch the shoot from a distance to see if blade or blades turn. if not then your problem is in the area of top pulley and blade or blades. You may need to replace or loosen the pulley to blade shaft. Sometimes this part is repairable where you can replace bearings or bushings and sometimes the whole unit needs to be replaced. Look to see if there are grease fittings on this unit. Try oil anywhere it will flow down in between areas that may be seized and work on loosening up the pulley blade assembly.
If this doesn't help, go to some of your local mower repair shops, they may be able to sell you a used part. Remember to bring mower information with you so they can help you with the correct part.
I hope this has been helpful to you. GOOD LUCK.
Jul 19, 2011 | Briggs & Stratton Briggs Stratton...
My murray riding mower chokes out when engaging drive train or when engaging blades... any suggestions?
i had a murray years ago and i had to replace some bearings but i don't recall were.
Sep 28, 2010 | Briggs & Stratton Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,909 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
