Question about Rainbow Vacuums
I need a manual for my Rainbow E series vaccum cleaner...R7866...E2 Do you have one I can download. I lost mine
SOURCE: I don't know how to take apart me Rainbow e2 series vac.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=767886
I don't know how to take apart me Rainbow E2 series...
Posted by tomang6 on Jul 10, 2008
I'm in the process of replacing some parts on my Rainbow and found out my Rainbow has a filter around the motor. I can't figure how to get my Rainbow apart to get to the motor to see if the filter needs replaced.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Rainbow E2 Series can be complicated and the best way if you are to do it yourself is to contact the Rainbow factory; to get the owner’s manual and check the trouble shooting and or a schematic to see the break down. As per the filter – the water in the pan is actually the filter; there is a rubber gasket that you could replace and there are screw under the gasket but the biggest maintenance is the cleaning of the separator, take a newspaper and place it under the Rainbow and turn on the vacuum without the water pan underneath and spin the moisture out of the motor for a period of 30 to 45 seconds. Also, there are a lot of wires under the housing so make sure you mark or label your wires when you install or re-install the motor section. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 11, 2008
advacak
  • 125 Answers
SOURCE: i don't have the aquamate
any shampoo made for extractor type machines will work fine, or mix liquid laundry soap 50-50 with water (after all, you AREwashing fabric}
Posted on Dec 16, 2008
  • 11 Answers
SOURCE: e series
The clear lenses on either side of the top part of the E-series Rainbow are removable. If you look at the each lens you will see two sections on the top edge of each lens that looks like this |___| |___| about 1 1/2 inches in from each end. Put a small screwdriver in the middle of each one of these (I used 2 screwdrivers at once) and pry out. The clips will come undone and you can remove the lens this way, exposing the screws which hold the motor cover on. On my E-2, there were 4 screws under here, and once I removed them, the top came right off.
Posted on Mar 06, 2009
  • 11 Answers
SOURCE: Rainbow Model e Series will not start. Where is the reset button on this vaccum?
There is no reset button on the canister. It may be a bad power switch, a power cord, or the button that presses in when you put the water basin in place may be bad - or the prong on the water basin that pushes that button in when you place the canister on the basin may be broken off.
Posted on Jul 03, 2009
  • 41 Answers
SOURCE: RAINBOW E SERIES REPAIR MANUAL
You can get the schematic for the E series here, http://www.elkypro.com/hoops2005/vacuum_parts/rexair/E-2.html There are actually two different models of E series model E-2 vacuums.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Posted on Jun 13, 2010
Our rainbow e2 black type 12 vaccum was meant to be used on 110v and was plugged into a 220v, what part needs to be changed to convert the machine to work with 220v
nothing that I can guess at but changing the motor to a 220 . might be more cost effective to purchase a new vacuum cleaner .or use a 110 convertor for your outlets
May 22, 2016 | Rainbow Vacuums
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
Nov 04, 2015 | Rainbow E series Canister Wet/Dry Vacuum
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Hi. I found it on amazon, here: Amazon com rainbow vacuum manual. I hope I have helped. cheers
Mar 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Shampooer will not work on my e2 Rainbow. Help!
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
Thank you,
Ralph
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to maintain up keep on my rainbow vacuum
Be sure and never store on water basin, keep separator and seal on bottom of rainbow clean. Keep your beater bar clean. You should be good for many many years.
Jul 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
I recently took mine apart because the motor stopped working. Realized the brushes were pretty well worn down and one side was completely gone. I was looking on the internet for detailed instructions on how to take it apart. I ended up just ripping it apart with no problems but made a tutorial to help you guys out. Here's a link to it
http://www.vacuumcleanerforum.com/f20/21715-how-take-your-rainbow-vaccum-apart.html
This is for the e-series vaccum, not the e2 but they pretty much have the same design and same motor (e2 has a 2 stage motor).
Let me know if you have any questions
Jul 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
160 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
