Question about Garden
I've replaced the pull cord on my trojan 16(teuchemesh engine) but the mower will not start now
  • Phil Saunders May 11, 2010
    Hi - need a bit more info..... In what way does it fail to start? If the recoil assembly is now jammed, it's likely that the cord has 'jumped' the pulley groove. You will need to pull it apart again.
  • 1,147 Answers
Make sure you dont have the plug wire pinched.
Posted on Oct 04, 2009
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
Replace pull cord
Go o you tube on line, how to replace pull cord mower
May 24, 2014 | Champion International Champion& Small...
Starter cord won't pull all the way to start engine. Engine 300 series 4.50 Lawn mower
Remove spark plug pull cord. This will release compression blow out cylinder. Replace spark plug try cord.
Aug 03, 2013 | Garden
Cord won't pull more than a few inches on new mower. Seems locked up. I've only ran it once.
Ensure the cable for the dead man switch is not kinked. Follow the cable from the handle to the engine. There are 2 bolts that mount the dead mans switch to the engine , remove bolts, remove dead mans switch from engine, let hang, try starting. If starting, clean dead man contacts and reinstall. You may have to remove recoil rope assembly and engine cove to get to dead mans switch.
Jul 04, 2012 | Troy Bilt 5.5hp Self Propelled Mower
The pull cord on my Cub Cadet OHV 173cc self propelled mower broke.. I'm somewhat handy and should be able to fix it myself, however I've never done this before. I have the engine housing...
Yeah I got the same problem. My pull cord broke in the first season. On my own once the plastic cover is removed, 4 phillips screws, the cord housing is secured by 3 10mm nuts. Remove them and lift out the housing. On my own unit the spring had also slipped out of the mount on the shaft securing the assembly (another 10mm socket nut will loosen that). I used a Briggs and Stratton cord from another (truly dead) mower and have had no problems since then. I am not sure why folks are giving you spark plug settings when you are asking about the cord. :)
Aug 14, 2011 | Mtd 19 In. 173 CC OHV 3-In-1
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Apr 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Pull cord stuck to motor housing
Ok You have to release the engine brake. BY pulling down the bail to the handle as if you were going to start the engine. Hope that helps.
Oct 21, 2009 | Garden
Lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
May 30, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
