Question about 2wire 2700HG-B Router (2700HGB)
Trying to hookup an ATT router 2701hg-8 i've lost the instructions can u help?
    Problem Solver:
  • 8 Answers
Hi..
If you want to hook it up wireless you need to synchoronize it to laptop. look 4 the last 3 digits of SN # its your network name. you needto connect to it by searching for network within range. click on your network name and hit connect it will ask for password which you can find near the SN under barcode it the 10 digit number enclosed in a bracket. after that you still need to configure your 2wire.
just the same procedure if you will just use a direct connection via ethernet cable just connect the 2wire and pull up internet explorer to configure it (firefox will not work on this). use address bar to access 192.168.1.254 look at the bottom right hand side near the box icon you will see run system set up wizard click it and set up a pw or if its ad\sking for one and you dont know it just click i forgot to reset pw system key is the 10 digit number in bracket. click again on run system set up , click next one keycode is encoded, pick any timezone. concentrate on user name and password field its very important and case sensitive. username is your AT&T primary user name and password. just tyoe it accurately, hit next and BINGO you'll be connected...
Posted on Sep 27, 2009
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
2701HG-B ATT modem/router won't answer ping 192.168.1.254
what is the default gateway for the ip address of whatever computer you are using ?
Not sure if they can change it but looking up the default gateway ip address will give you the router ip address if DHCP is being used and if it has changed somehow ?
Jun 06, 2017 | 2wire (2701HG-B) Wireless Router
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
I have a 2wire 2701hg-b router....I can connect to the internt through wifi on my laptop but when I try to connect through ethernet on my desktop it says it accuirring signal. I tried to reinstall the...
First look in device manager and verify that the network adapter is enabled, if so you can try disabling it then shut down and reboot the PC.
Once booted, go back into device manager and enable the network adapter.
Run the software that came with your router and follow the steps provided.
Make sure your network cable from your router is NOT connected untill instructed to do so.
You will need to have the network cable from your modem connected to your PC for the router software to detect network connection.
Good luck, I hope this helps.
Have a nice day.
Jun 01, 2010 | Computers & Internet
I installed an ATT 2701HG-B gateway this weekend,
AT&T has nothing to do with it.
Kindly call Misrosoft so that they can help you with it
GEt help from a local computer Geek to Remove and Reload Your Entire Operating System
Jan 12, 2010 | 2wire 2700HG-B Router (2700HGB)
2701HG-B only works with ADSL
Your ADSL router won't work for that Cable service. You must buy a new router. I have Trendnet router at my home (also it's wireless too) and i had no problems with that router. Working fine. About price, the 54Mbs version is 54$ including shipment
Aug 26, 2009 | 2wire 2700HG-B Router (2700HGB)
Att2wire 2701hg-b to replace peoplepc dsl Zyxelp-600 series modem
do you also have AT&T? att2wire 2701hg-b gateway is configured to work with AT&T only that's why if you have a different ISP, it will not work for you. Most ISPs provide modems that are configured solely for their service.
Apr 26, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
1,143 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
