Dont know how to connect dvd player and digital set top box to the same tv. set top working,dvd player not showing visuals on tv
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
