Question about Vacuums
Hoover windtunnel u6476-910. Brush does not roll. Flat belt and other belt are good. The other thicker belt (called V belt?) does not have tension with the brush roll. How do I make sure it is engaged? Is there a fix? Settings are in "Carpet", "Roll-on", etc. Cleand all hair and bags/filters already.
  • bayfolks Sep 26, 2009
    I already took the screws off. And had checked the belts. The 2 belts are in position. But the thicker V belt has no tension against the brush roll. Did you not read my question above? Please read, else we'll waste time. Let me know if you can/cannot answer?
    Hoover windtunnel u6476-910. Brush does not roll. Flat belt and other belt are good. The other thicker belt (called V belt?) does not have tension with the brush roll. How do I make sure it is engaged? Is there a fix? Settings are in "Carpet", "Roll-on", etc. Cleaned all hair
    Comments:
    Sep 26, 2009 - I already took the screws off. And had checked the belts. The 2 belts are in position. But the thicker V belt has no tension against the brush roll.
  • 986 Answers
These machines had a defective switch and a bulletin was sent out to all service depots. If you contact any Hoover Warranty Depot, they will replace the switch, wiring harness and tool receiver under a no-charge warranty. It doesn't matter how old it is, but it must be listed in the serial number listing as one of the defective machines. It is possible that the switch just failed, as any switch can, and that your machine is not one of the affected models of the early switch, which means that they would charge for the repair work. You can go to www.hoover.com and check the serial number to see if your's is one of the defective ones. Other wise, you can buy a switch and install it yourself or have a repair shop do it.
Posted on Sep 26, 2009
    President:
  • Vacuums Master
  • 1,723 Answers
Flip it over and take the 4 screws out of the silver plate covering the bottom. The belt is probably off and needs to be attached.
Here is the manual showing you how on page 10
http://www.hammerwall.com/Download_Manual/14551/
Changed belt , it broke again not sure why
gotta make sure both ends of brush bar are clean and turn freely
Apr 22, 2015 | Hoover U5753-900 WindTunnel Bagless...
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Had a problem with the brushroll now its burning up the flat belt
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Dec 21, 2008 | Hoover U6630-900 WindTunnel Bagless...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel Self-propelled - brush roll stops
There is a idler wheel that will drive the V belt, sometimes they jam and you just have to reach in, push and make sure if comes in contact with the belt. Alot of times tho it is the other flat belt, 38528035 that will stretch and can cause you to have problems with the brush roll not turning.
Feb 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
