Question about Dell 1710n Laser Printer
Do not print delivery address on envelope - Dell 1710n Laser Printer
2 Suggested Answers
  • 37 Answers
SOURCE: Dell Inkjet Printer (not sure its a 720, but it's similar)
Switch the pink cartridge with the black one.
Posted on Aug 19, 2008
How do I print envelopes using Word 2013
  1. On the Tools menu, point to Letters and Mailings, and then click Envelopes and Labels.
  2. Click the Envelopes tab.
  3. In the Delivery address box, enter or edit the mailing address.
  4. In the Return address box, you can accept the default return address or do one of the following:
    • Enter or edit the return address.
    • Omit a return address by selecting the Omit check box.
  5. If you have access to electronic postage, for example if you purchased it from a service on the World Wide Web, you can add it to your envelope.
  1. To select an envelope size, the type of paper feed, and other options, click Options, select the options you want, and then click OK.
  2. In the Envelopes and Labels dialog box, do one of the following:
  • To print the envelope now, insert an envelope in the printer as shown in the Feed box, and then clickPrint.
  • To attach the envelope to the current document for later editing or printing, click Add to Document. The envelope is added to the document in a separate section.
Oct 02, 2013 | Toshiba e-STUDIO 165 All-In-One Laser...
Printing envelopes misalligned
Check your printer settings. Make sure you still have the proper size envelope selected. Sometimes, the settings change back to factory default when doing maintenance.
Dec 15, 2012 | Epson Stylus NX400 InkJet Printer
How to print envelopes
1.Buy envelopes at any office supply store. They come in all shapes, sizes, textures and colors, so choose ones that go with the type of invitation you are sending out.
2.Open Microsoft Word 2007 and click on the Mailings tab.
3.Click on Envelopes in the Create section.
4.Click on the Envelopes tab when the Envelopes and Labels box comes up. The box will probably come up with the Envelopes tab open, so you may not need to do this.
5.Enter the recipient's address in the Delivery Address box. Invitation envelopes should include the names of everyone invited--for example: Mr. and Mrs. Smith, Mrs. Smith and family. Don't worry about the font at this point--you can change it later.
6.Enter your return address in the Return Address box. As with the Delivery Address, you can change the font later.
7.Click on Options. Use the drop-down menu in the Envelope Options tab to change the size of the envelope if needed. The packaging of the envelopes that you purchased will have information about the size of the envelopes. It is very important that you choose the correct size so that the envelopes print correctly.
8.Adjust the font of the delivery and return addresses. Click on Font in each section and change the font style or size. You can also bold, italicize or choose other options regarding the font.
9.Adjust the placement of the delivery and return addresses on the envelopes. In each section, click the arrows in the "From left" or "From top" boxes. In the preview section below, you can see the movement of the addresses as you adjust the placement. Line up everything so that it looks good to you.
10.Click on the Printing Options tab. This is important because you must select how you feed the envelopes into your printer. Choose the correct way that they are fed, whether they are fed into the printer face up or face down, and if they should be fed in manually. This will all depend on your specific printer. Consult your owner's manual for this information if you are unsure. Click OK and you will return to the Envelopes and Labels box.
11.Insert the envelopes into your printer. Click Print once you have everything formatted and arranged how you want. You should print one envelope first to make sure the layout is correct. Once you've confirmed it printed correctly, print all your envelopes.
Sep 21, 2011 | Canon imageRUNNER 1023 Black and White...
I want to print on lower left corner of envelope, how? I will print which office to direct mail. Probably 50 envelopes at a time.
Go to the screen where you address envelopes.
Select OPTIONS
See the Delivery Address Font Option. There is a drop down to select the distance FROM LEFT. That means from the left side of the envelope. Set that to a low distance.
Jul 06, 2011 | Microsoft Word 2003 for PC
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have wedding envelopes that I am trying to print on that are A9 size. The delivery address prints (sometimes) but the return address will NOT print. The "Check Printer" light always starts flashing, and...
Did you set the printer to use A9 envelopes? You can go to the printer software or printer options and set the printer to print on the size paper you select.
Jan 24, 2010 | HP Photosmart C3180 All-In-One InkJet...
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Can't print envelopes
    is this the first time you use word ?
    if it is any of the newer version 2003, 2007. the printing of envelope is as follow:
    open the word, elect tools>>envelopes and labels. type in the delivery address and return address. click add to document.
    completed you letter.
    whenyou want ot pin the envelope, hig light the delivery address on the document, file, pirnt, type in 0 (zero) in the pages box under the page range (in the middle of the popup, under the "curent page button).
    Mar 26, 2009 | Samsung ML-2510 Laser Printer
    Printing on a #10 envelope
    Go into your Word Document and print from "Tools" then "Letters and Mailings" and click on Envelopes and Labels. Sometime the perimeter isn't defined and it is on there but it's outside the scope of your envelope, especially if the return address isn't in the correct place also. You may even be able to correct it where you are by decreasing the "window" of your typing space, it's just too large.
    Jan 17, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
    Dell 1710n Laser Printer Logo
    90 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    Electro Med Services...
    color wheel light...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
