Question about Nikon Coolpix 4300 Digital Camera
Taking apart I wanted to know how to take this camera apart. I have all the screws out but the top doesn't want to separate. Do I need to take the round menu button off and if I do how do I do that? Thanks JL
I have the service manual in pdf format, drop me a line at info@tradecctv.com and I'll forward it - one thing though - have you taken out the screws under the battery flap? and no - no need to remove the menu button.
Cheers
Jim
Posted on Jan 20, 2008
Taking cover off nintendo ds lite
Are you talking about the back cover or front cover?
Either way, before starting you are going to need two things: A tri-wing screwdriver and a Philips screwdriver.
To remove the BOTTOM COVER, you must take off the stickers covering the screws and remove the screws. 001e10e1-317e-4bb5-97cd-230a82f77aaf.jpg
Then, carefully pry the back off, revealing the motherboard inside.
To remove the TOP COVER, you must take off the stickers covering the four screws in the corners of the INSIDE top screen. Unscrew them and gently push the inside top screen down until its about half a centimeter apart from it's backside. Then pull the backside off and you have it open.
If you wanted to open the DS completely, like have it in half, you should first open the BOTTOM COVER and remove the motherboard after disconnecting it from everything attached to it. Then follow the steps given for removing the TOP COVER and slide the ribbon and cables sticking through from the TOP to the BOTTOM back to the TOP so that they are not sticking through and won't be damaged when you take the DS apart. Then unscrew the power light and voila! The DS should be separated.
May 31, 2014 | Nintendo DS Lite
Hi I have a sharp portable AC unit model CVp 10lc works for 1hour
I have the same problem. I have only used my unit 3 times. It keeps "triping" and shuts off. Also, I smell a plastic burning smell and the plug gets very hot.
Apr 02, 2010 | Sharp CV-P09FX Air Conditioner
I have some dust on the sensor of my fx500. not sure how it got there, but it's there. anyone tried taking one of these apart for cleaning? is it fairly straight forward?
I have the same camera and the same problem as I always keep the camera with me in my pocket. The camera can be taken apart and cleaned if you have a clean work space. I would not attempt this if you do not have experience separating electronics with delicate ribbon cables. Wants the camera is apart it is easy to see why this happens as there are several gaps in the lens barrel. If you have patience it can be done but I recommend as much of a dust free environment as possible, some cleaner for a DLSR sensor and some air duster. When I tear my camera down I start with the bottom and work my way to the sides. The most difficult part about separating the camera for me is the top portion of the camera where the zoom control an on off switch is located is attached permanently to the flash and the flash capacitor. This needs to be wiggled with the utmost care and pulled straight up and out of the camera. Once the camera body, sides front and top are separated the LCD screen lifts up and there are a couple of screws that screwed directly into the back of the sensor mounting bracket area once these screws are removed the sensor is easily accessible. Again you do not have experience with not touching anything while you're doing work like this do not attempt this. Once the sensor is pulled up a can be dusted and cleaned my typically blowout the lens barrel with the air duster, obviously making sure that you do not tilt the can because even the slightest residue will set you back even further.
Nov 15, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
How do I remove the LCD screen from a Samsung Blast?
you must take the back cover of and remove the six screws to access the lower portion of the phone. Once you've done this remove the qwerty keypad. When you slide the phone back down you should see the back of the slider and two additional screws. Good luck.
Feb 25, 2009 | Samsung SGH-D600 Cellular Phone
Taking apart a A530
Leave the mode selector wheel alone. It is not necessary to remove it. Take a look at the following A530 disassembly guide. It should be of help:
http://photography-on-the.net/forum/showthread.php?t=251630
Apr 24, 2008 | Canon PowerShot A530 Digital Camera
Lens does not extend
If you drop one of the Coolpix cameras, the case can get jammed up against the lens. The lens may not extend at all, and you are probably getting SYSTEM ERROR messages. The motor that extends the lens isn't powerful. By loosening the screws that hold the case together, you may be able to move the case slightly and get everything back into alignment. This task is for the mechanically inclined and who can be gentle and patient. Brute strength is NOT called for here. Also, if your camera is under warranty, do not do this!
Removing the case screws will require a jewelers phillips head screwdriver and a well-lit workspace that will prevent losing the screws (they are tiny). Not all the screws are exactly the same. You have to keep track of where they came from so that they go back into the same hole. Get a clean sheet of paper and draw a map of the camera body showing where the screws go. There are 11 screws all together two of which are under the battery cover.
Shut off the camera and remove the battery. As you remove the screws, place them on the corresponding spot on the map. When all the screws are removed, the case may not want to come apart. GENTLY move the two halves of the case apart at the bottom of the camera (For some reason, the camera wants to come apart at the base before the top). It probably isn't necessary to take the body apart. If the body does come apart, note that the OFF/ON dial is connected to the circuit board by a thin ribbon cable, so the halves cannot be separated completely in any case. DO not pull on this cable.
What you are trying to do is loosen the two halves of the case and give them a chance to get back into the original position. Note that the tripod mount is a separate piece and will shift slightly if you separate the case halves at the bottom.
If the case halves are loose and they have moved, you've may have fixed the problem. Replace the screws. You may need a pair of needle nosed pliers to get the screws back into the holes. Put the battery in and turn on the camera. If you moved the body correctly, then the lens should pop out. Don't be afraid to try a couple of times.
I may have been lucky in that this worked for me, but if your camera isn't working at all (mine wasn't), this may be worth a try. Just be extremely careful of those screws.
Mar 29, 2008 | Nikon Coolpix 4300 Digital Camera
Camera doesnt work!!!???
If you're an adventurous soul, you could remove the screws holding the phone together and check for damage to the ribbon-cable leading to the top half of your phone, where the camera is. If it is in good shape and you are willing to continue your foray into the inner-workings of your phone, you could try to separate the case covering the top half of your phone so that you could assess the condition of the camera itself. Unfortunately, I can't help you in that surgery on your phone since all I have is half a phone I found in the street that I'm attempting to repair... However, if you need info on taking the lower half of your phone apart, you can find my fix here- http://www.fixya.com/ThreadView.aspx?prdid=401432&thid=393581
Hope this helps, TechnoWolfy.
Feb 20, 2008 | Sanyo MM-8300
Step Switch replacement
Take off the cap on top, remove the 3 screws, then the top comes apart and you can get to the switch.
Feb 04, 2008 | Filter Queen Cheetah II Ash - MU305...
Repair issues...
Please visit http://www.averatec.com/docs/5100-doc.pdf and look for your solution.
Mar 23, 2007 | Averatec 5110HX Notebook
Nikon Coolpix 4300 Digital Camera Logo
110 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
