Question about Refrigerators
Quit cooling and frozen solid
We have a 16 year old GE side-by-side that just quit blowing cold air. It ran constantly. The tech we had come out said to defrost it and then plug back in and it might hold out til he gets in a new defroster motor which will be $150. We did defrost it and now it's working great. Do we really need this part after all? Thank you-Kim
  • franktalk May 11, 2010
    In less than a month or so,the ice will start to build up again and your problem will be back. You need a defrost timer for a frost free unit
  • 725 Answers
Yes you do... unless you want to manually defrost it every 2 weeks...the frost will come back about 2 weeks or sooner... you can change the defrost timer your self if you are handy...
let me know what you find... i can help you
Posted on Sep 26, 2009
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Feb 24, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Quit blowing cold air
if a leak, should be repairable, a lot of techs these days find it easier and more profitable just to replace things. try a new tech
Sep 04, 2009 | Dometic Rooftop RV Air Conditioner
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
26 year old refrigerator quit cooling. neither the refrigerator or the freezer side has any cool air. actually, the inside is hotter than the outside air.
Bad compressor. Or, it's lost all of its "Freon". Not really cost effective to repair, call a service center and get a "best guess" quote.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Msd2432grw problem - freezer not frozen and clicking off sound
This sounds like a stuck compressor, you really should call a service tech. to verify that the compressor is faulty or maybe a bad start relay. A qualified service man can verify this problem. If it is in fact a bad compressor you will probably opt for a new refrigerator.
Jan 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
