Question about Dryers
Just changed the capacitor in my hotpint ctd00 and now it wont blow hot air. The element is not getting hot
    President:
  • 1,922 Answers
Could you have bumped a wire off the element terminal, or element itself could have opened up,the hi-limit or cycling switch could also be bad
Posted on Oct 03, 2009
Dryer not heating up
To be certain whether it is the element or thermostats that are faulty,you really need a test meter to check them with, as it is not obvious if they are faulty or not, simply by looking at them
Hope this helps.
Please rate my solution.
Thankyou.
Dec 21, 2009 | Hotpoint Dryers
My electric dryer wont heat took off the coil part
There are 2 things in series with the heating element.
One is on the element housing. One sets the amount of heat and the other blows out if it gets to hot from things that block the air flow.
Nov 03, 2009 | Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Hotpoint ctd00 tumble dryer does not get hot at all
Most probable cause is open ciorcuit thermostat/s. Replace stats, if still no go, then replace heater element.
Pleas rate my solution.
Thanks.
Jul 16, 2009 | Hotpoint Dryers
Drying Problems with a Hotpoint CTD00
There is a thermal fuse at the back that you must check. The thermal fuse can be tested using a multimeter.
If the fuse is ok, then check the heating element , the temp probe, wiring harness to heating element and temp sensor, and if there is nothing in there , then test control timer board.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 27, 2009 | Hotpoint Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
