Question about HP iPAQ h6315/h6365 Pocket PC
Backup and restore
Hi.
After I've backed up my files onto my storage card, do I remove the storage card before I do a hard reset?
    Sniper:
  • 146 Answers
You can format your phone without taking the card out from your phone...because when you format your phone...it does not format your storage card...
go ahead and format your phone...
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 05, 2008
How do i reset my acer aspire to its factory settings
Hi and Welcome to Fixya!
To restore your machine back to the factory settings, just follow the simple step mentioned below. Be sure that you've backed up your personal files though before doing this because resetting your machine will wipre out any changes you have made on the machine.
For an Acer machine, just press Alt+F10 when you boot up the laptop. You will see Acer Recovery Management, select "restore system to factory default settings" then follow the on-screen instructions and you should be good to go.
Hope this helps!
Takasashi
Jul 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
My HTC Desire HD has just frozen. The screen is now black and no buttons work. When I connect it to the battery to the mains I get the coloured welcome screen for a few sceconds but then it goes black...
Please reset the mobile ,
Resetting Your Device Soft reset Occasionally, you may need to reset your device. A soft(or normal) reset of your device clears all active program memory and shuts downall active programs. This can be useful when your device is running slower thannormal, or a program is not performing properly. A soft reset is also necessary afterthe installation of some programs. If a soft reset is performed when programs arerunning, unsaved work will be lost. To perform a soft reset 1. Remove theback cover. 2. Use the stylustip to press the RESET button located between the SIM card and the storage card slots. Your device restarts and displays the Home screen. Hard reset You can also perform a hard reset (also known as a fullreset). A hard reset should only be performed if a normal reset does not solve asystem problem. After a hard reset, the device is restored to its defaultsettings-the way it was when you first purchased it and turned it on. Any programs youinstalled, data you entered, and settings you customized on your device will be lost.Only Windows Mobile® software and other pre-installed programs will remain. Warning! Your device will be set back to factory default settings. Make sure thatany additional installed programs and/or user data have beenbacked up before you perform a hard reset. Managing Your Device Important IfEncrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset,or updating the ROM system software. Otherwise you will no longer be able toaccess the encrypted files on the storage card. Use ActiveSync or WindowsMobileDeviceCenter to transfer files between your storage card and computer. After theprocedure, copy your files back to the storage card. To perform a hard reset 1. With thedevice turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button. 2. Continuepressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen: This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel. 3. Release theVOLUME UP and VOLUME DOWN buttons. 4. Press theVOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | HTC Touch HD Smartphone
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
I have buy a new htc p3470 mobile fone.i have a
try a hard reset of your phone:
this will get you back to factory default and take you through wizard for setup.
1. Remove the back cover.
2. Press and hold the SOFT KEYS, then use the stylus to press the RESET
button located below the battery compartment.
3. Release the RESET button, but
continue pressing the SOFT
KEYS until you see this message
on the screen:
4. Release the SOFT KEYS, then
press TALK/SEND to perform the
to manufacturer default.
Press Send to restore
manufacturer default, or
Clear Storage
Another way of clearing the device storage and reset all settings back to
factory default settings is to use the Clear Storage feature. You will lose all
your data and files on the device storage when you use Clear Storage, so
make sure to do a backup first.
Important If Encrypt files placed on storage cards is or was enabled before, then
reset or updating the ROM system software. Otherwise you will no longer
storage card.
1. Tap Start > Settings > System tab > Clear Storage.
2. Enter “1234”, then tap Yes.
Your device restarts and displays the Quick Setup Wizard
Mar 27, 2010 | HTC P3470 Smartphone
Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to english.is it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
1.
3.
Using Clear Storage
If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
1. Tap Start > Settings, and then tap All Settings.
2. On the System tab, tap Clear Storage.
3. Enter "1234" and then tap Yes.
Dec 17, 2009 | HTC Touch Diamond Smartphone
How can I do Hard reset my HTC S730 ?
1) Click Start
2) Click Expert
3) Click "Clear storage"
and follow on-screen instructions to reset your phone.
REMEMBER that all of your data will be deleted and the phone returns to factory deafult settings.
That should be all :)
Aug 21, 2009 | HTC FUZE Smartphone
Restore information
I can understand you very well since I use a PDA also and this battery problem is an issue for me too. I assume that your backup file is in your storage card and is a standalone exe file (means you don't need your backup software being installed first to start a recovery process). You can remove your storage card from your PDA first and back it up to a PC to ensure that your only backup file is safe. Next, you can do another hard reset to your PDA and do all the settings steps again. After that, you can try to recover some of your data by starting the recovery process and performing not a full backup, but just the necessary data first. I am recommending this step because you have a PDA that's main storage area is very limited (like mine) and if you are normally using it filled up, backup process can be terminated before it finishes because of the backup file is nearly equal to the total main storage area,  and this causes your device to stop working even after your incomplete recovering process. This is mainly becuase recovering process needs lots of space and when the process is near the end, it can't have enough space on main storage area to continue. So, you can try to recover the necessary data first (Softwares, contacts, appointments, ...), then, if it is successfull, you can open your backup file again and this time you can select the other personal documents that has been left in the first process. (I hope your backup software supports selecting the needed data to recover.)
Apr 13, 2009 | i-mate Pocket PC
Possible to restore data after a Hard Reset?
look here for your files
C:\Program Files\palmOne\[username]\Backup
and
C:\Program Files\palmOne\[username]\address
Now that you've made this mistake once, you probably want to get a backup program. I use the built in backup in Resco Explorer. They also make a stand alone application.
For your SD card backup might look at Bluesync.
For a free option you can use the PFB (palm file browser), but I would still manually backup the card with a cardreader attached to the pc on occasion.
Nov 10, 2007 | Palm TX Handheld
Axim after a hard reset!
Well to make a long story short, after the hard reset I lost all data, and I put the axim in the cradle and it sync-ed but I had to create a new name for it, and it never brough the software that I had originally installed on the unit back... is that common and everytime we'll do a hard reset on it, will we have to re-install all the software and assing a new name to the unit, if so than it is ridiculous!!!
Sep 14, 2005 | Dell Axim X3 Pocket PC
Soft & Hard Reset
Correct, a hard reset restores the PPC to its origional state. Soft resets are similar to rebooting your desktop computer. You can backup your device with either ActiveSync or the included utility. I don't have a device so I can't give you exact steps, but I believe what you are seeing is where the device will store the backup. You have to put it on a storage card in most cases, not back on the device.
Sep 13, 2005 | Dell Axim X5 Pocket PC
HP iPAQ h6315/h6365 Pocket PC Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
