Question about Craftsman 25cc Gas Line Trimmer
Craftsman weedeater25 cc fuel ratio - Craftsman 25cc Gas Line Trimmer
2 Suggested Answers
  • 221 Answers
SOURCE: I need to know the gas to oil ratio on my 17
4 oz of a generic 2-cycle oil to a gallon of fuel is the typical mix.
I hope this helps.
Posted on Jun 17, 2010
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
Oil & gas ratio for an older Craftsman chainsaw?
Unless the saw is over 40 years old, 40:1 ratio will work well. Really old saws required 30/32:1 ratios when petroleum based oils were used. Be sure to premix the fuel and a modern synthetic saw oil in it's own can and be sure to shake thoroughly just before refueling each time. Check the H jet setting by warming the engine up, then pull the throttle full on. Proper adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Be sure to check the fuel filter, air cleaner and muffler for plugging before making any jet adjustment. Hope this helps!
Jun 26, 2010 | Garden
I need to know the gas to oil ratio on my 17" 25 cc craftsman weed eater.
I hope this helps.
Jun 17, 2010 | Craftsman 25cc Gas Line Trimmer
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
What is gas/oil ratio for 25 CC leaf blower
Hi Rambo,
Unless otherwise specified, the normal ratio is 2 ounces of 2 cycle oil for every gallon of gas.
Best regards,
Mike
Oct 18, 2009 | Craftsman Garden
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
