Question about Sony KP-46WT510 46" Rear Projection HDTV
I have a scoop or 3d look how can i fix it
I have a scoop or 3d look how can i fix it the picture is coming from the middle.
  • Sony Master
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
Acer gd235hz 23.6 lcd monitor is blank on the right side only the left side of the screen shows pictures
It sounds like the monitor is broken. You should probably just buy a new one. If you haven't already, try checking the cable connections to the pc. Outside of that, there's not much you can do. Hopefully you still have a warranty on it and cant have it fixed.
Oct 18, 2017 | Acer Gd235hz 23.6" Lcd Monitor - Black
Middle of the top of the picture in distorted and out of focus. color is displaying only purple at the top
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to fix the tv convergence board,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP74 56" Rear Projection...
Stupid RCA TV....3D picture, 3 colors...replaced FL231 fuse...still didnt fix it...grr...=(
U replaced the one the middle out of the three?Yes,Still the same problems,just replaced all three convergence fuses caps than.Must resolders the FBT- flyback tranformer too.
Nov 19, 2010 | RCA P52926 52" Rear Projection Television
Picture problems
Is it one color that has moved? Sounds like a convergence problem. Find a channel with a fixed picture, or if you have digital cable or satellite pull up a guide, something with a straight line across the screen. You will likely see one of the colors is bowed or or shifted. You may be able to adjust that with your remote under the "convergence" adjustments in the menu. If it will not adjust it will need work done to the convergence circuit. Not a DIY project.
May 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our convergence control is not working. Looks
ok here is the scoop there are 3 fuses on the deflection board to the lower right of the flyback transfomer they are square and brownish on of them is open you can have tehm replace with a 4 amp pico fuse and check the solder joint on the flyback this can cause the fuse to blow
Dec 04, 2009 | RCA R52WM24 52" HDTV Projection Television
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Rca 56 inch, picture looks like its in 3D
Go to menu then setup if you do not see convergence in menu then FL231 is bad it is on right side of FBT flyback Transfomer on the deflection board their is 3 of them in a roll small brown rectrangler looking caps but are fuses it will be the one in the Middle if fuse is good try this with set off Press and Hold at same time vol- and ch- see if set will come on this is How to Enter service Mode.
Aug 26, 2009 | RCA R56WH76 Projection Television
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Sony KP-46WT510 46" Rear Projection HDTV Logo
269 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
