Extreme heat can cause warping and the cd will not evenly eject or exit the slot. the player may have to be removed and the cd physically extracted from the player. Delco players have a lot of plastic cogs, flywheels and gears in them that get old and crack or split. Hence, the player can no longer spit out the CD.
Hello! The "E20" error code loosely means that the CD player cannot focus, or read the disc properly. This could be from a number of reasons, dirty pickup lens, dirty/scratched disc, excessive humidity, or using a burned/copied CD that was burned at a speed that was too fast to provide a "deep" enough burn to the disc. And lastly, I know GM's Delco radios in the late 90's had issues reading CD-RW's; but read CD-R's fine (if burned slow enough)
My first suggestion would be to see if this happens on all CD's - originals and/or burned ones. If it only happens on burned/copied discs - I'd recommend slowing down the burn speed to no faster than 16x and retrying. If it does happen with both types of discs, then I'd purchase a CD lense cleaner and run that through a couple of cycles.
Hope this helps and good luck! Thanks for using FixYa!
If cleaning didn't help,then replacing is the way to go.You can go to a local stereo shop and see if they can fix it easily.they might know the trick on doing it.It's worth a try.Don't go to Best buy.I know you have seen one as you were driving around town,just pull in and see what's up,They may have fixed one as the same as your Nissan.
are they Burned or copied CD's? CDR, CDRW? cause if they are some radios will not read them and give error messages. if not try using a lazer lens cleaner CD, they sell them at most music stores, you may have lint or dust on the CD lens with summer weather, and pollen in the air and dust, CD player lenses take a beating, so get a WET lazer lens CD cleaner, and that should help fix the problem
It's just an error message. It stands for Error 20. There is no way to fix the problem. It only reads cd's that it wants. But if it does play a cd, then suddenly stops, and says E20 and spits the cd out, it's most likely because the cd player got too hot. My car does that all the time. And it won't play a lot of burned cd's. Hope this helped.
Could be a number of things. Some of the older GM CD players don't work too well in very cold weather. Also, some of the older CD players won't play burned CD's. If it's not cold weather related, and you're using a regular production store-bought CD, then it is most likely an internal radio problem. Cheapest solution is to buy a cheap aftermarket player.
This happened to my 2004 as well just last month. It kept spitting the CD out and giving me the error message. I took it into the dealership and since it was under warranty still, they just replaced the whole radio system.
