Question about Gateway 566GE (RB566GE) PC Desktop
When i turn on my computer the on switch will not keep the computer running if i unplug the 4 prong square plug that is pluged in to the mother board then the power supply works and the computer stays on what is my problem
  • 63 Answers
Well your screwed unless you take it to a professional. you should never unplug those.
Posted on Sep 27, 2009
Computers
Power Supplies usually don't get faulty. Sometimes my BIOS would get stuck & I plug the Lithium Battery (Coin Cell) out and plug it back in & Everything works fine. For example this problem is like having a USB storage stuck at copying/deleting something and you have to PULL IT OUT and PLUG IT IN to make it work again. Sometimes this type of problem may occur with SATA Cables, the one who connect motherboard with harddisk. Sometimes the ram would get faulty. Process remains the same. In 10 Years of my computing history I don't remember facing any problems with Power Supply Unit.
Hope this is revelant.
Jul 08, 2013 | Audio Players & Recorders
Hp pavilion slimline x3507c pc. when I boot up the monitor remains in standby mode. I have already determined that the problem is in the computer not the monitor. The power supply is good, the fans run,...
very simple bring a new AGP card and plug in it on your pc and plug the monitor pin in new agp now start your computer . monitor will turned on.
if the monitor is not turned on its mean your have problem in your ram or mother board for that pluged out your all rams from your pc and start your computer if cpu ring a beep its mean you have ram problem and the mother board is ok but if you cant hear any beep its mean mother board's problem ram is ok.
Jul 16, 2011 | HP Pavilion Slimline s3700f PC Desktop
No power,power supply seems ok,green light on mother board on. when pluged in the fan runs for a couple seconds and turns off.power button has no effect.
sounds like a mother board issue,
start with pulling out all ram chips and re try,,
then try pulling all cards out like old modem and also cdroms.
if ever thing but power is unpluged its a bad mother board or CPU chip
Mar 12, 2010 | E-Machines T3958 (827103050974) PC Desktop
When I attempt to turn on my computer after playing with the switch front and back it will start sometimes and run for a few minutes and then shut down. When I remove the four pin connector to the mother...
I've seen this before but the 4 pin connector was burnt pretty bad and not making a good connection. I'd see if you could gently scrape the pins a little bit with a small knife(motherboard) See if the connector from the power supply looks ok and doesn't look like it's gotten hot. The holes in the center of the 4 wire connector can be a little bit larger than the pins themselves also. You might try plugging in the connector and then holding some side pressure on the connector while you try to start the computer. Also unplug the hard drive and cdrom while you try booting. The power supply may not be putting out enough amperage and unplugging drives may give it a little more power. That would mean you might need another power supply if it works.
Nov 29, 2009 | MSI 865PE Neo2-V Motherboard
My computer speakers
i took the side pannel of my pc and check the plug that goes to my sound card on the mother board and unpluged it and pluged it back in and it worked thk you
Nov 05, 2008 | Durabrand Audio Players & Recorders
POWER ISSUES? OR MOTHER BOARD......
IT WAS THE POWER SUPPLY. AS SOON AS I PUT A NEW UNIT IN, IT BOOTED RIGHT UP... NO PROBLEMS YET AND IT'S BEEN ABOUT 20 HOURS. I WAS TOLD THAT A POWER UNIT WILL DO THAT BEFORE IT GOES FOR GOOD(ALONG WITH *********** BOARD)....
Aug 28, 2008 | Sony VAIO VGC-RB34G PC Desktop
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
ASUS p4s533 will not start
Your motherboard is bad and will need to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 08, 2008 | ASUS P4S533 Motherboard
Mother board
about the small connectors, there is white text printed into the motherboard showing what goes where.
about the drives, check your cables.
May 03, 2008 | Computers & Internet
Cmos reset
If you have the manual for *********** board if not print it out, there should be a 3 prong with a jumper on it.. usually you turn off the computer take it off switch it to the prong that wasn't covered and the center prong let it stay there i thin 3-10 seconds then switch it back. turn on your computer and it should be reset
Mar 27, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
