Question about Vizio VW42LF 42 in. LCD HDTV
Vizio picture is blurry on hd channels as well as regular channels and have hdmi cables
Highdefjeff
  • 124 Answers
SOURCE: Sharp Aquos LC-65D64U Picture Quality
You need to change your TV's settings and enhancements. Directly from the store and out of the box, the settings are adjusted for easiest sell in the store. That means that:
Your contrast is cranked to 100. Move this down to 50 to 60.
Your brightness may also be cranked up high. Lower it to a level nearer the middle range but not so dark as to lose detail in the shadows.
Your TV is set on "Dynamic" or "Vivid" mode. Pick "natural" or "normal" or standard.
Your sharpness is at least on, if not cranked up. Turn sharpness down or off, and the same with "Edge Enhancement" and "VSM", all to off.
Lastly, I bet you upgraded size and you are now sitting too close to the TV. Roughly, if you are sitting closer than 130 inches (about 11 foot) you might do some rearranging or save some money and get a smaller TV.
Posted on Apr 08, 2008
SOURCE: TV not finding Digital Channels from Cable Box
I just bought Sony LCD 46 inches, with model KDL 46 V 2500 about less than 9 months,now TV lost digital channels, I tried every thing to program it but it's not working, when I program it the screen come up and stay about 20 minutes for searching digital channels then disappeared.and always no digital found.I don't know what wrong?
Posted on Feb 07, 2008
robmonroe
  • 67 Answers
SOURCE: Vizio flat screen has very red tint when using HDTV component cables
Sounds like you may have connected the cables incorrectly, or the cable may me bad. The cable company likely provided you with component video cables, which are red green and blue. Ensure that these are connected to the correct plugs on both ends of the cables.
If that does not fix the issue, I would ask for a replacement cable or box.
You may also be interested in buying an HDMI cable if your box supports it.
Posted on Jun 11, 2008
  • 108 Answers
SOURCE: No sound on NON HD channels
Check menu on tv and see if the audio input has any other settings. May have different options for sound processing.
Posted on Jan 06, 2009
  • 105 Answers
SOURCE: Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Posted on Apr 29, 2009
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My HDMI cable is hooked up from cable box to backside of TV. My HD does not seem to be working.. I have gone through input and HDMI settings without any upgrade in picture..
You only get a HD picture if the cable or satellite provider is sending it in HD, otherwise you see it in regular format. Your set can produce only what it receives.
Dec 29, 2010 | Vizio L37 Television
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
HD to SD/SD to HD channel switch causes the picture to disappear
try using component cables instead if you are using an HDMI cable to connect to the tv to the STB
Jun 07, 2009 | Vizio GV42L 42 in. LCD Television
Sound and picture interference when changing channels from hd to regular tv model VX37L vizio
It may be the cables you are using. You will need to HDMI cables for high def and rca or coaxil for regular
May 09, 2009 | Vizio VX37L Television
Blurry picture
In the store they use an HD source and connection. Is your cable box HD? It will have component or hdmi connections if it is.You have use either one to get HD everything else will be SD(standard def).And you have to be on an HD channel.Digital cable refers to how the signal is delivered doesn't mean its HD. SD channels on digital still look bad..
Rustym62
http://www.the-tv-dude.typepad.com
Apr 28, 2009 | Televison & Video
Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
May 21, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VW42LF 42 in. LCD HDTV Logo
1,121 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
