Question about Garden
My weedwacker stalls out when i try to increase the speed and also stalls after running about 20 seconds
4 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Weedwacker stalls when accelerating
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 25, 2009
lonewolf1996
  • 142 Answers
SOURCE: troybilt weedwacker won't stay running. It starts
you may need to rebuild the carburetor.Check all the gas lines for cracks or leaks.Check the primer bulb if it has one.Then try and readjust the carburetor.If that still don't work,then try to rebuild the carburetor.
Posted on Sep 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: weedwacker stalls out
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
How how to adjust the screws on the carburetor of the yard machine yard cultivator 31 cc
Hi Christi:
This is a "standard approach" that i've used for various small engines for a long time. It may not be factory specs, but it's worked for me.
- First, gently turn both screws in (clockwise) until they just touch the seat. BE GENTLE as you don't want to damage the needle or seat.
- Second, back out both screws 2 turns. This is a "guess" start point.
- Third, start using normal procedure.
- Once the choke can be opened, with the saw at an idle, adjust the slow speed screw until the saw runs at its slowest smooth idle.
- Finally, increase the engine speed and adjust the high speed screw.
Try turning it clockwise.
- If RPM increases, continue until it starts to decrease, then back off 1/4 to 1/2 turn.
- If RPM dropped or engine stalled, back off 1/2 turn and try again.
Hope this helps.
Aug 31, 2015 | Garden
HOW TO SWITCH 6260 TO 60HZ
6260 isn't a model number for any Ingersoll Rand generator.
Generally, though, if you have a generator that generates 50Hz and you want it to produce 60Hz instead, you adjust the governor to increase engine running speed by 20%... if the engine will tolerate that speed. The first thing you need to do is find out what speed the engine runs when it's under normal load. If that speed can't safely be increased 20%, then the generator head has been built strictly for 50Hz and there's nothing you can do about it except run a UPS between the generator and your load.
If the engine speed IS low enough to safely increase by 20%, then that's what you do.
Jul 03, 2014 | Ingersoll Rand Electrical Supplies
My truck starts and stalls and will not idle
Try increasing the idle speed. If you don't know, this is how to do it.
Open the bonnet and ask someone to push and release the gas pedal a five second intervals.
Observe which part is moving.
Yo will see a small adjustment screw on that lever. You will understand that by adjusting the screw you can increase the gas supply to the engine.
Slowly rotate the screw while the engine is running. (If the engine doesn't run in idle state as you have explained, ask someone to keep the pedal slightly pressed. After increasing the gas supply, ask the person to release the pedal).
Adjust it further to get a smooth running condition at idling.
Also check whether air cleaner is blocked.
Aug 30, 2011 | GMC Sierra 1500 Cars & Trucks
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman model 358.791042, gasoline weedwacker wont stay running
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
Jim
Jun 21, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
