Question about Garmin StreetPilot c550 GPS Receiver
Will not let me change locations while moving how do i turn off that fuction?
  • 504 Answers
This is a safety feature that comes turned on by default. While you are driving, you cannot enter new directions/information as it is unsafe to do so. The unit normally asks you if you want to override this at the time, but you can also turn it off while stopped by pressing the icon at the bottom of the screen that looks like a wrench. Then press "System" at the top middle of the unit. Where it says "Safe Mode" press the "On" key. At the next screen, press "Off." The unit will now allow you to enter information while it is in motion.
Posted on Dec 26, 2009
Flasher location relay
On a 1993 olds ciera, the flasher unit for the T/S is clipped to the ashtray mount bracket. Remove the ashtray and the flasher will be on the passenger side of the bracket. The emergency flasher unit is located to the right of the glove box when facing the box. It is hidden behind the Multi -fuction alarm module.
Oct 30, 2013 | Oldsmobile Cars & Trucks
Turn signal flasher location
fuses first, usually its 1 fuse but some cars have 2.L/R
remove all left lamps. (lamps can short !)
put a new one in.
does it work?
yes,
now move it to the other end,
does it work? i bet yes. (not both work , try it)
if not someone , cut the wires, for trailer hitch (uhaul blunders)
or collision damage that side. f/r/
if all checks fail, the combo switch is dead.
one other test with new lamps, is try the emergancy flasher ,button, does that work?
Oct 08, 2013 | Jeep Liberty Cars & Trucks
How to remove multi fuction switch from 94 cougar
the switch itself must be changed ,the fault is the switch as their is no other unit ,it should just prise out the facia on this vehicle,hang on this is the american vehicle not out europeon similar named vehicle but it could be the same so ask a local mechanic with experiance to confirm would be a good idea
Dec 19, 2012 | 1997 Mercury Cougar XR7
I have a 2001 Oldmobile Intrique and as of late the turn signals don't work properly. Sometimes they will function but now they simply don't come on or work only during the first turn and then...
I would guess that the turn signal switch is worn out
You said they work some times,so the flasher is good
You need a repair shop i assume
You didn't meantion your expertise in
troublshooting electrical issues
Jul 14, 2011 | 2001 Oldsmobile Intrigue
Want to turn off the annoying beeping sound every time i push a button on the unit, remote or adjust the volume
Turn the unit off by pressing and holding the volume button till it powers down (NOT VIA THE IGNITION SWITCH!) Once off, press and hold the fuction button (located in the top left hand corner near the volume dial) until unit lights up again and a menu appears, near the end of that menu you can change the beep noises to off like volume or when ignition is off but unfortunatly you cannot change the beep for changing track.
Jun 27, 2009 | Pioneer DEH-P6800MP CD Player
My quickie motorized wheelchair is making a loud buzzing sound when turned on, but I can still move around, Checked for moisture, dried with hair dryer. Is it the horn Can I disconnect? How? What else can...
Honestly I don't know if I can solve this problem, but, when do you get the buzzing sound, when your in motion? (in other words moving) what brand do you have? It shouldn't be making the noise unless you have the QLogic Controller that can make beeps when you move to a fuction... Let me know more...
Feb 21, 2009 | Quickie Wheelchairs Health & Beauty
Excel
The Data Analysis Add-in has a Moving Average fuction and wizard. Moving Average
Aug 30, 2007 | Microsoft Office Standard for PC
Vs-50605 Mitsubishi
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
May 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Garmin StreetPilot c550 GPS Receiver Logo
52 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
