Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
No Turn On
I have a schematic of the power supply and have used it to check it's components. The only thing I found was a open 560K resistor in the string of four that bias the FET. With the set off and pluged in, the voltage on the COLD side is only about half what the schematic calls for. Is this normal?
Thanks
  • Philips Master
  • 5,138 Answers
Look for 2.2uf 100v cap near flyback.
Posted on Jan 27, 2008
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
Power supply is only 12months old very little use. Was working fine but one day failed to turn on..its not overloaded its rated way,way above what my system should need. Being an auto electrician I thought...
Hi
This resistor is for overload its like a protection unit your system may Overload but you need a multimeter to test the Diodes and you might find that one of them is short this can cause the resistor to blown
you can find this resistor in High Voltage circuits
hope it will help
ecrdn@yahoo.com
Jack
Nov 02, 2010 | Thermaltake 700-Watt Power Supply
ViewSonic N3250W Television with FSP212-3F01.dead needs VOODOO
I am working on the same power supply right now, my has a bunch of bad caps that I already replaced but I did not try to turn it on yet becuase I see that RS1 and RS8 are missing, some one had try to fix this power supply. Can you please tell me the value of these two resistors? Please see my pictures at http://s807.photobucket.com/home/budm/allalbums
Your problem sound like the logic board problem, I can tell you what you should have if I can find out if these two resistors were left out from the factory or some had removed them. I fixed the same power supply for the N2652 but I did not take the pictures of the board, I wish I did.3a99fcd.jpg
Jun 17, 2010 | ViewSonic N3251w 32 in. LCD HDTV
Press power button just clicks, no power. Found
The best thing to do here that is easy-----get at the two STK-392-110 CHIPS and un-solder both of them--if the set then comes on--one is bad--you might also take a close look at all the low value resistors around them--all have location numbers on the top of the board--like RK51 etc.
If you find a discolored resistor--or if unsoldering the chips lets the set turn on----you have found your problem.
Let me know if you have questions or need help--I am here to help people.
SD TECH
Oct 23, 2009 | Hitachi 43UWX10B 43" Rear Projection...
ATX-300GU PSU: 32V around Q4/Q5 circuit
could just be the regulating power transistors are burned out or one of their biosing components, there a few meaty capacitors that may be causing a surge, but the safe thing to do would be to start with a new one, the reason is, modern drives are so sensitive that you could blow their circuitry and then lose the harddisk! All the best - the Yeti
May 17, 2009 | AOpen Power Supply: ATX-300GU (PS4300GU)...
Akai PDP4225M std/by red light only
1st your power supply needs replaced. But you could have issues with the sustain boards and or your panel that is causing your power supply to fail. once you replace your power supply you should be able to power up the set, but if you don't get a picture then you will have to trouble shoot the sustain boards and panel.
Jun 30, 2017 | Akai PDP4225M 42 in. Plasma Television
AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
this is because R001 is not 5.6 ohms, it's 560K ohms
Nov 10, 2008 | Akai PDP4225M 42 in. Plasma Television
TV will not turn on
does the standby led goes on, or non at all? if not, check power supply section, look for blown fuse or open resistor in the power supply section. check also the power regulator IC...
Sep 28, 2008 | Olevia Televison & Video
Benq Q7S3
Video Graphics Card in Computer "BAD" !
Nov 15, 2017 | BenQ FP567s 15" LCD Monitor
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
99 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
