Question about KitchenAid 24 in. KUDP01DL Built-in Dishwasher
Kitchenaid dishwasher leaves slimy film on everything
My Kitchenaid dishwasher leaves a brown slimy film on everything! Including the inside of the dishwasher which is stainless steel. We have tried disconecting and cleaning out all tubes, drains etc... The machine seems to work fine meaning it cycles normally drains and dries the dishes. I have tried a multitude of detergents and rinses. I have also run it thru a cycle with vinegar to clean it out. That works for a short time then the film is back. This machine is only about 5 years old.
    Habit-Forming:
    New Friend:
  • 34 Answers
Dishwashers are made to last 5 to 7 years.
Posted on Sep 26, 2017
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
  • 93 Answers
SOURCE: KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Posted on Jan 21, 2009
SOURCE: Normal cycle leave dishes half clean. Heavy cycle
in the bottom of the machine, under the bottom rack, is a screen looking piece. twist or just pull up, should be able to clean that then replace.
Posted on Aug 08, 2009
heatman101
  • 43501 Answers
SOURCE: White chalky film on everything
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jul 22, 2010
heatman101
  • 43501 Answers
SOURCE: my kitchenaid dishwasher leaves a
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Posted on Mar 29, 2011
Dishwasher leaves white film on dishes
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 17, 2011 | KitchenAid Dishwashers
Our 15 year old kitchenaid dishwasher is suddenly leaving a white film on all the dishes. Never had this problem before and we are using the same detergent as always.
heatman101
Apr 14, 2011 | KitchenAid Dishwashers
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Cloudy film left on glasses and white residue on edgings on inside of door as well as white residue streaks on inside of door.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 23, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
The dishwasher leaves a film residue over all my glasses and other dishes. I changed detergents and rinse agents and it still happens
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Jan 12, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Leaving white residue on glasses and dishes
heatman101
Dec 24, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
Stainless steel drum-some hard water build-up inside leaving residue on some dishes...how do I clean interior of dishwasher. A home-made solution worked years ago but have forgotten the ingredients!
heatman101
[][][p
Sep 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
heatman101
Jul 21, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
My kitchenaid dishwasher is leaving a white film on all my dishes no matter what setting i use.
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 09, 2010 | KitchenAid 24 in. KUDP02FRSS Stainless...
KitchenAid 24 in. KUDP01DL Built-in Dishwasher Logo
238 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
