Question about Panasonic Cordless 12V Compact Impact Driver Kit with 2 High Capacity 3.5Ah Ni-MH Battery Packs
Panasonic EY7540 impact driver. Does not go into reverse on 1st
Panasonic EY7540 impact driver. When I switch from forward to reverse it keeps going forward for the first time after I press the trigger. When I let go it then will reverse and stay in reverse after that. Then I will switch to forward and it works fine. The back to reverse and for the first trigger pull it will stay in forward. I release and pull trigger again and if will go into reverse mode. What is causing this. It has happened since it was new. Thx Greg
EY7540 14.4 volts. Both batteries were fully charged. Operating the driver in various positions would result in the Red battery charge and temp. light coming on and the operation of the driver would die. Pointing the driver up, it was OK. Pointing it down it failed. All connections and solder joints were checked. All joints in the battery cct board were checked. By the way I am an electronic technician. Any ideas?
Posted on Sep 12, 2010
    President:
  • 1,714 Answers
The forward/ reverse switch is hanging up and the rotation of the drill is switching it, then it changes direction. The switch needs a little TLC and a good cleaning. Blow it out.
Posted on Sep 26, 2009
My impact driver when in reverse works fine but when in forward it will work for a few seconds then stop and keeps doing that. why?
I'd be looking for a defective forward/reverse switch, or a bad connection/wire on the forward side between the switch and the motor.
Jul 01, 2015 | Dewalt DW056 18V Heavy Duty 18V Cordless...
How do I get the M18 light to turn off it stays on all The time
If it's the white work light ? Has someone worked on it recently ? Does the work light go off when pulling trigger? Are the forward and reverse switched ? It could be the blk and red wires on the brush card assembly are switched.
Feb 20, 2015 | Milwaukee M18 Compact Drill & Impact...
My makita 6914D impact drill works fine when it will start. Sometimes when I pull the trigger nothing happens on either forward or reverse. When I change batteries it may or may not work . I checke
It could be your brushes are worn down and not fully contacting the armature. If they are very short and the armature comutator looks burnt, you need part number CB424 to replace your brushes. Most likely your problem is the switch. Sometimes the contacts in the switch get dirty or burnt and if you move the switch just right, a clean contact may be made but usually it won't work. The switch is part number 651939-6. Both are available on sites like www.ereplacementparts.com.
Mar 01, 2014 | Makita 6914D 12V 1/4 in. Impact
Ws550 eletric. i need the forward and reverse switch for my ingersoll electric wrench
Ask your IR dealer for this part > IR 201718 SWITCH, last price I saw was around $38.00
Sep 12, 2013 | Ingersoll Rand Ingersoll-Rand 1/2 in....
It's not spinning
sometimes the forward/ reverse switch gets stuck 'inbetween' make sure it is fully in forward or reverse. you did not attempt to operate it in the video, is it air or electric?
Mar 07, 2013 | Tools & Hardware - Others
Have a problem with Hitachi WR22SA Impact Wrench Rotates in the forward (on) direction but not in reverse (off) Can you tell me what is the likely problem?
Please try to locate the forward/reverse push button switch. Please try also referring to your users guide. Forward/reverse has a different or separate switch. Thanks for asking.
Jun 14, 2011 | Hitachi WR22SA 3/4" Electric Impact Wrench
Hitachi Cordless Impact Driver gearing problem
The speed shift slider switch wasn't lined up correctly when the unit was reassembled.
Unfortunately, you going to need to repeat the disassemble/reassemble process once more.
I've been there. It doesn't take much to be out of alignment. Set everything to the lowest setting (clutch, speed) and take your time.
Best regards
Mike
Apr 22, 2010 | Hitachi DV18DCL 18V 1.5Ah Lithium-Ion...
Makita 12v impact driver- no reverse
I would suggest that you go to Makitatools.com and type in your model number and look at the breakdown for complete disassembly procedures. The only problem it could be it the tab on the switch or the shift lever is broken I would have to think it is the switch. Let me know if I can help more.
Mar 29, 2009 | Makita 12V Cordless Impact Driver -...
Model cd55 Ryobi cordless drill driver
Your drill probably has a bad or stripped drive gear. Does the drill operate in forward w/a battery that is not fully charged but yet good.?
Sep 12, 2008 | Makita 6932FDWDE 14.4V Impact Driver
Panasonic Cordless 12V Compact Impact Driver Kit with 2 High Capacity 3.5Ah Ni-MH Battery Packs Logo
422 people viewed this question
Top Panasonic Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Richard Warren
Richard Warren
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
