Question about Sony STR-DG800 Receiver
Need to save my pre set channels on the radio
  • 49 Answers
Once u have found the channel u want press memory button then the selected number, hope this helps
Posted on Sep 27, 2009
How to unlock uniden gmr325-2
Unlock.....?? What do you mean unlock? The radio is pre programmed with set channels. You would be unable to set your own frequency channels. The FCC has some very stiff penalties for people who use radio frequencies outside of the assigned band and on radios not type accepted for the use. Sorry....
Jun 18, 2014 | Uniden GMR-1088 2-way Radio Walkie Talkie...
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
Feb 20, 2013 | Chrysler Cars & Trucks
I lost the password and access code & CD to set up other computers to my wireless router. Is there any way of reseting it?
Hi Friend,
Make sure that the wires are connected properly to the oruter and the computer. Push and hold the reset button for 30 seconds and turn off the router. Turn it on and perform the steps;
1. Type 192.168.1.1 in the web vrowser and hit enter. Leave the username blank and type admin in password,hit enter.
2. In the setup page, if you have cable connection, make sure Automatic DHCP configuration is selected. If you have DSL connection, select PPPoE from the menu and enter the username and password. Click Save settings.
3.Click Wireless and fill as mention:
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Radio band: Wide
Wide Channel;3
Standard Channel:1-2.41GHz
SSID Broadcast:Enabled. Click Save settings
4.Click Wireless security and fill as mention:
Security Mode-WPA personal
Pre-shared key-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
I hope this will resolve the issue.
Regards
Chiranjeet
Sep 27, 2010 | Linksys WRT300N Wireless Router
I need to set the clock on a CD/cassette radio in a 1999 Ford E 450...also how do I set preset stations too?
Station Pre Set:
You can save 4 pre sets on this radio (1-4) tune the radio to the station you want to save then PUSH and HOLD one of the pre set butons until the sound returns, the station is saved to that pre set. Repeat for the 3 presets.
Clock:
Hour: Push and hold the CLK button and at the same time push the SEEK button to adjust. < decrease hours > increase hours.
Minute: Push and hold the CLK button and at the same time push the TUNE button the adjust. < decrease minutes > increase minutes.
Jul 14, 2010 | 1999 Ford Super Duty F 450
I'm using the pre set cb radio band to scan cb, howevre I locked out a few channels that I would like to unlock. how can I do this?
press the manual button until you get to channels you locked out, then press Lockout and they will unlock.
Thanks,
Dodgem250.com
Apr 15, 2010 | Radio Shack Pro-97 Handheld Scanner
How do I enter a code into my BMW business rds radio (Philips) model
with the pre-set station keys, press 1 then then use channel up/doun to select correct digit..
then press 2 use again channel up/douwn key to select correct digit, repeat same with 3 and 4, then press pre-set key 5 that puts in the code,DONE!
O.K.?
Mar 10, 2010 | 1997 BMW Z3 Roadster
How to pre-set radio channels
After some playing!
Use 'Auto-Scan to find required channel
Select 'Memory' ; 'Memory shows on control panel
While 'Memory' still shows, press preset button for required channel number
Programme is set
Jun 20, 2009 | Venturer Audio Players & Recorders
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
Feb 15, 2009 | Panasonic Car radio CD CQ-C1110GN CD...
Cant figure how to hook my stereo up
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
Jan 29, 2009 | Audio Players & Recorders
I have a problem
Normally in a Motorola T5700, to set a specific channel to monitor (and reply to) called your working channel, you press the Menu (center) button and the current channel shown in the display will flash. Press either the + or - buttons to change to your desired channel number which should be identical to both radios. Press the PTT button to save.
Likewise, both radios must have identical Interference Eliminator Code. To set code, press Menu till the code display blinks. Press + or - to select code. Press the PTT to save. To disable the code, select 0.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Sony STR-DG800 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
