Question about Dell Inspiron 1100 Notebook
Inspiron 1100--fan has recently started running often & long. Computer gets very warm to the touch & runs very slowly. Shuts down randomly--during virus scans, disk clean ups, etc
  • 3,940 Answers
Sounds like the heat exchanger is clogged. Try using canned air blowing in both the air intake and exhaust to unclog the heatsink and also make sure the system has the most current BIOS version.
Posted on Sep 26, 2009
Freezer not cooling
The clicking you are hearing is probably the compressor trying to run but shuts down after the minute. If your refrigerator has a fan cooling the compressor make sure if is running and the coils are not blocked with lint. A warm compressor is a good sign a hot one is not. The compressor start device or relay could be causing the problem.
Apr 01, 2014 | Refrigerators
Dell Inspiron 1525 shuts down
You have had Win 7 for TWO YEARS? Hmmmm well anyway thats the problem. You see Win 7 and games don't MIX, the only way may help is to run in compatibility mode for XP SP2, and Run & Install as Administrator.
Mar 19, 2010 | Dell Inspiron 1525 Laptop
Inspiron 1100 wont boot up,screen stays black,i can hear the fan running,sounds like hd is starting
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
Check for PSA Error codes on support.dell.com.
If all Test Passed. Then Perform Dell Factory restore or OSRI.
Jan 20, 2010 | Dell Inspiron 1100 Notebook
Computer Randomly Cuts off
processor overheating. When it gets too hot it automatically shuts your pc down and boots it back up. Even if the fan is running, it could not be supplying enough cool air anymore.
Jul 27, 2009 | Computers & Internet
I have a eu3000 overload safety shuts it down at about 1100 watts
Can you verify the amp draw on the output? This gen should handle 25 amps continuous. I wonder if you actually have a bit more that 9 amps? It would be nice to check the frequency and volts too...A Fluke multi-meter can read these values.
Jul 23, 2009 | Electrical Supplies
Laptop running Vista gets 'blue screen' and shuts itself down
Cooling is the key to keeping your computer free of these type of issues, the Blue screen of death is famious for microsoft, What is happending is the machine is getting hot and needs a rest from the overnight work it does, Solutions are:
1. fan under cpu needs to be cleaned
2. can buy a fan to put under unit to help airflow
3. Keep room temp 75 F to avoid heat
Make sure you run windows update on a side note.
If you found this information ot be helpful use the fixya as a rating this helps us with our status here and keeps us here helping you in our free forum section thanks
Apr 24, 2009 | Dell Inspiron 1420 Notebook
This type of problem happens a lot. Usually its associated with heat and dirt(dust). A good cleaning will increase your air flow and probably fix your problem.
Either way you MUST see whats happening inside...it can certainly be insects clogging critical areas...I've seen it before.
Apr 24, 2009 | Toshiba Satellite A135-S2386 Notebook
Computer Shuts down
Well your processor may be damaged..
dont worry may be it is not damaged so what do you do is that open the cover of your computer.... Then start it and keep the cover opened making sure that you can see the processor fan running...
See that if the processor fan is running...
then with the help of a torch see that may be the fan is being restricted or it is moving slowly.
this slowness of the fan heats up the processor and makes it shut down you PC
if the is running slowly take out the fan using the user guide of the processor and then lubricate it with motor oil.
it IT Does not work then there is a problem with your processor so please check by placeing another supportive processor and check it!
Dec 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Dell Inspiron 1100 Notebook Logo
60 people viewed this question
Alun Cox
