Question about Garden
Engine turns over strong but will not start.
I have Craftsmen 22-inch slef propelled law mower. Model # 917.371940 it turns over strong but will not start. Mower is about a year or two old. Fuel filter plugged? Water in gas?
Also how do change the oil? I could not find drain plug underneath enginer>
Thanks!
  • vince janis
    vince janis May 11, 2010
    If it has a fuel filter check it, if you you have water in gas it definitely will not start. If there is no drain plug on the side of your engine, it is most likely underneath your mower deck, either a set screw type of plug or a square head type of plug. Still can't find oil drain tip the mower over in the direction of the fill tube but make sure you drain gas first or you will have a big smelly mess. Check for water in tank by disconnecting hose from carb and empty gas into clear jar if there is two levels of liquid then you got water.
  • 28 Answers
I'd pull the carb bowl off first and see if it has water or other crud in it. there should be an oil drain on the bottom, sometimes they are an allen socket plug which sits fairly flush
Posted on Oct 03, 2009
Looking for repair manual for husqvarna 175cc 22 in self propelled rear wheel
Search by engine model #. If not engine problem search by mower model #+parts.
Jun 12, 2016 | Husqvarna Garden
If I haven't added Stabil to the gasoline for my Craftsmen 675, will that keep it from starting?
Ethanol gas can gum up the fuel system if left in unit for to long from now on use ethanol free gas in all small engines
Jun 22, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
How much oil does a 675 briggs & stratton 22" lawn mower take?
HI There try adding oil a bit at a time. They will only need minimum amount to lubricate the engine. Firstly put in about a quarter of a litre and check the dip stick after 10 mins.
Sep 23, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I have a constant vibration when running my poulan pro self propelled 22 inch cut lawn mower. any solutions to the problem......
My guess is that you have hit something pretty solid while mowing. You have either bent the blade, bent the crankshaft, or both. To check for a bent crankshaft, set the mower up on a table or tailgate where the handle is on the ground and the spark plug is pointed into the air. DISCONNECT THE SPARK PLUG !!! You don't want to risk starting it in this position. While a friend holds the engine brake lever closed, and pulls the rope, you need to watch the blade bolt. If the bolt spins without wobbling, just replace the blade. If the bolt wobbles, then the crankshaft is bent. A bent crankshaft can be straightened by a reputable shop. Not all shops are will to straighten crankshafts. It is not a cheap repair.
Aug 23, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Poulan pro 22" self Propelled mower wont start
Yes go to an Advance auto or other auto repair store and pickup a Briggs and Stratton repair manual for the engine you have , the manual will cover all single cylinder OHV engines just make sure it includes your model number . These manuals are usually around $15.00 and are quite comprehensive and a good buy if your interested in repairing you own lawn equipment. It sound to me like when you reassembled the engine you have the ignition out of time which would cause the backfire you describe. Hope This Helps You Don
Dec 06, 2009 | Poulan Pro 22" Self Propelled High Wheel...
The rear wheels on my 22" Husquvarna mower, self propelled
sounds like the reinforcement bar across the back is broke or missing
Aug 18, 2009 | Garden
Toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
