Question about Onkyo HTR500 Receiver
Receiver tuner out after lightning strike
I have a Pioneer VSX-D811 on a power strip, with the FM antena connected to the (cable) TV. After a thunderstorm, the tuner, FM and AM, no longer work, but all other functions in the receiver work fine.
    President:
  • 1,922 Answers
You more than likely have a F.E.T.(Field Effect Transistor) front end tuner,very susceptable to lightning or static charge damage, chech your home owners insurance, you might be able to repair or replace the tuner but it wont be cheap
Posted on Sep 26, 2009
Why cant I record FM from this Pioneer vsx921
To record from the built-in FM-tuner, you can use either the DVR/BDR or the CD-R/TAPE outputs of the receiver.
Mar 13, 2015 | Pioneer VSX-921K 7.1 Channel A/V Receiver...
Can't tune to any radio station
this can be due to some blown capacitors.
Jun 12, 2008 | Pioneer VSX-D903S Receiver
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
I'm trying to connect my cablevision coax to my Pioneer VSX-1019 reveiver so I can listen to FM radio through the tuner. The antenna connection on the receiver is a female European PAL (also called as...
Is this what you need? http://cgi.ebay.com/4pc-Gold-Plated-Aerial-Female-Aerial-Female-Adapter-/180435080974?pt=LH_DefaultDomain_0&hash=item2a02c4d70e
although I would be surprised if the signal you have would be correct to supply your fm tuner, you may be better off with something like this (depends on how good your fm signal is locally) http://cgi.ebay.com/FM-AERIAL-KIT-RADIO-RECEIVERS-BALUN-UNIVERSAL-/310283558296?pt=LH_DefaultDomain_3&hash=item483e575d98#ht_2068wt_876
Alternatively, and I know this sounds crude, poke a long piece of wire into the centre of the aerial socket on your tuner and pin it to the wall or a door frame, it often works if you have a decent signal to begin with.
Jan 11, 2011 | Pioneer VSX-1019AHK A/V receiver
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Pioneer vsx 3000 plays fine, but the radio function hums
If memory serves correct, the VSX-3000 is from the late 80's. They are good receivers from that era. From your description, it appears the tuner module could have issues, since only the AM/FM has a hum. If all other inputs sound well, it points the the tuner module. These modules are not easy to repair (PCB with SMD highly tuned parts), and are easiest and cheapest to replace. Many VSX models of that vintage use the same part. Not sure how easy it would be to find one. They are a small PCB enclosed mostly in a silver shielding, with one or two connectors from the inside and screwed to the back of the receiver, where the antena connection is.
Good luck
Jul 29, 2009 | Audio Players & Recorders
Pioneer-vsx-9500s radio won't work with cable
You cannot plug cable from the wall into a receiver, you will blow the tuner card.  Use the supplied antenna or go to radio shack and ask them for an fm antenna.
Jan 04, 2009 | Pioneer VSX-D509S Receiver
Hello all;;;;;; i have a pioneer vsx-9500s,,,,the problem is i ran cable to my reciever so my fm radio will work but it doesn't,,,,,,,,i checked the cable on a tv and it worked ,,,,so i know the line is...
Nonsense. FM is included in MOST tv cable subscriptions- make sure your subscription includes this service. Do you have another receiver/tuner to test with?
Check all the connections between the cable entrance and your tuner; eliminate all splitters for testing. If you can get another tuner to work on your cable, it may be time to check into your tuner-
There is no difference in signal level between tv and fm- your receiver is not gonna burn up! If it has a 75-ohm cable input, use it!
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
Av illiterate
Make sure your cables are all properly connected
Jan 28, 2008 | Pioneer VSX-455 Receiver
Onkyo HTR500 Receiver Logo
251 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
