Question about Lexmark X83 All-In-One InkJet Printer
Lexmark 83 will not pull the paper thru the printer
It starts to pull the paper then stops and starts printing. However it is not pulling the paper through so the ink is going on the bottom. After a minute it tries to pull the paper thru then gives a paper jam or system error A06 message.
SOURCE: Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Posted on Sep 13, 2007
SOURCE: Lexmark X3350 Printer
Thanks for everyones help, what worked for me is to reinstall the software that came with the printer. Works just fine now.
Posted on Apr 23, 2008
SOURCE: Paper keeps getting jammed in MP460
I had the same paper feed grabbing problem on pixma MP 610 printers - take a flashlight and look down into the feed rollers inside - deep - I found a paperclip in one and a hair clip in another - you need a pair of very fine pincer pliers to extract so you dont damage the roller assembly's made of plastic - and voila no more misfeeds and grabbing on the right side - hint - dont put anything on top of the printers because when you lift the scanner cover, it nicely slides anyting on top into the paper feed assembly and results in a jam
Steve
Posted on Aug 06, 2008
SOURCE: 'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Posted on Aug 20, 2008
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Hello. I have a Lexmark x4650 printer/scanner/copier and the paper starts to feed thru and then pulls to one side. I am then unable to print my document. Why does this keep happening and how can i solve...
Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any foreign objects that might have accidentally fell into it. If feeder is clear, open the printer cover and remove the cartridges. While the printer cover is open, check inside for any obstructions in the paper path. If none, then close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Close the cover. Load some paper (avoid overloading). Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jun 21, 2011 | Lexmark X4650 InkJet Printer
Lexmark x85 paper jams
I have owned several X73, X83, and X85 printers. Most of them end their life in the way that you are describing your problem. They will start by feeding the paper thru the primary load but will not feed the paper thru to be printed on and out the paper exit.
First and foremost, I advise you to unplug the printer, remove the flip top cover and turn the printer upside down and shake. I have seen items in the paper path such as a penny cause issues like this. Also make sure the paper path is clean and no small tears of paper in the way that could be blocking. If you find something check again, hopefully this is the good solution.
If that does not work, it is most likely that you need the print engine for the unit. Unfortunately this costs about $109 if you can find them (unless they got cheaper since I last checked).
If it makes you feel any better I have one that matches your's on the shelf here :) You can get a new AIO printer for $109 or just a little more.
Mar 22, 2009 | Lexmark X85 All-In-One InkJet Printer
Printer will only pull the paper in from one side.
Hi !!
Usually this problem happens if there is something wrong with paper feed rollers which is inside the printer .
But to fix teh problem you can try this ---
take out ink cartridges, all the cables, power adapter (black rectangular box at the back) and papers from the paper feeder . Then take the printer in your hands, keep it like upside down and shake it for a while .Then keep it back in its position
Afetr 10-15 mins , install cartridges, cables, power adapter and just 1 sheet of paper on the printer . try to print somethg if still it dows same thg then it means that This is a time to buy a new printer on this christmas !!
Regards
Priya
Nov 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Paper pulling
Be sure your paper guides are tight against the paper. If so, then clean the feed wheels with a damp cloth (just water). If this helps temporarily, you might need to replace the feed wheels.
Jul 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Jul 23, 2008 | Lexmark X85 All-In-One InkJet Printer
Won't print
Sounds like a piece of paper is stuck inside the machine. Open all access doors and check. Remove the printer cartridge and reinsert. Make sure the print job has been purged from the queue.
May 31, 2008 | Lexmark X73 All-In-One InkJet Printer
Print Output
Try cleaning the feed rollers. these are the rubber wheels that actually contact the paper and pull it through. If they get dirty, their grip on the paper will be less than adequate. Just use some clean water, or perhaps some rubbing alcohol, and a clean rag to wipe them thoroughly.
Feb 11, 2008 | Lexmark X85 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
