Question about Sony NW-A1000 MP3 Player
Sony nwa 1000 new battery fitted. would need the reset button to start. now doesnt start at all.
  • 63 Answers
Your device is corupted it happend to me with mine.
Posted on Sep 27, 2009
Mu harmony 1000 doesnt respond in any way when the buttons are pushed. The LCD Screen is frozen on the home screen. I have tried upgrading the firmand software...what can i do about it?
Try pressing the reset button, or holding the power button until it turns off. If that doesn't work take out the batteries and wait then put them back in.
Feb 28, 2011 | Logitech Harmony 1000 LCD Touchscreen...
Battery went flat. Battery removed and charged. When bike starts up engine dies when 1st gear engaged.
hi, as this got an alarm fitted, if so you may need to reset it. take battery lead NEGATIVE ONLY you need to place the NEGATIVE connector ON and OFF the battery quickly. this is a RESET OF SYSEM do NOT FORGET TO BOLT THE NEGATIVE CONNECTOR if alarm starts i think you have to switch ignition ON. gerry
Sep 08, 2010 | 2000 Honda VTR 1000 SP-1 (RC51)
Is it possible to open up the NWA-1000? e.g. to replace the battery?
Yeah, of course it is possible, but the only thing is that you've got to be very careful. Usually on mp3 players, the back is usually where the battery is. So I suggest you use something like a flat screw driver to gently open the clips.
Feb 06, 2010 | Sony NW-A1000 MP3 Player
Stuck installing my Pioneer DEH-1000E
yes try that. I had a Isuzu Bighorn and put a new Sony CD player in, but i used the old casing to fit the new one. so you could try using the old casing, or buy a new one.
Jan 10, 2009 | Pioneer DEH-1000 CD Changer
2006 Aprilia RS125 doesnt start
Hi .... Try switching the petrol off just prior to stopping the engine and start up again with the petrol OFF. There's enough petrol in the carb to start the bike. A good battery should show over 12 volts. Take the plugs out and give them a good clean or replace them. Is there a petrul pump fitted ? A two stroke needs to be ridden quite hard to maintain efficeincy, higher revs etc ........ let us know how you get on ?
Dec 19, 2008 | 2006 Aprilia RS 125
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Screen freezing at start up
Does it make a clicking noise when you switch it on, then your hard drive is broken and needs to be replaced.
Jul 29, 2008 | Sony NW-A1000 MP3 Player
Nwa-3000 music plays but no screen shows up!!!!
Reset
Update Firmware
Double-check with Sony
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
If fails, then the player is officially dead
Feb 23, 2007 | Sony Network Walkman NW-A3000 MP3 Player
SOund Interferance
I have a similar problem. If you put a bit of pressure on the top right corner of the mp3 player (i.e.: clamp it between a couple of your fingers) the sound becomes fine again. However, in my case, the problem eventually became worse, up to the point where I couldn't hear anything at all. I think you'll need to get it serviced to fix the problem. I'm sorry I can't help more than this. Adam
Jan 02, 2007 | Sony NW-A1000 MP3 Player
Sony NW-A1000 MP3 Player Logo
57 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
