Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Ights on, no cooling, ''hrs'' flashing,
GE Profile Arctica refrigerator(ge pss26sgrss) problem: lights on, no cooling, ''hrs'' flashing, no other digital read outs. Hard reset from circuit breaker does not fix it.
  • 1122 Answers
SOURCE: GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
Posted on May 29, 2008
SOURCE: GE PRofile Arctica
Got mine fixed!
http://www.fixya.com/support/t867206-ge_profile_pts25lbmarww_power_but_no
Posted on Aug 07, 2008
  • 42 Answers
SOURCE: I have a GE Profile Arctica. Refrigerator side
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: HRS flashing, nothing getting cold
Your refrigerator has a control board on the back behind a metal panel. Unplug and look at both sides to see if you see burn marks or loose solder. Go to this site and place model PS123NCRBV into the model search feature.That will take you to 13 similar models. The board on back is my first concern and the control inside will need to be looked at also if you find no problems on the back. The control board number is WR55X10656 let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
  • 2187 Answers
SOURCE: Problem with ice dispensing. I
I am not sure if I understood the problem. Please bear with me as I try to provide solutions to common symptoms.
The Touchpad if it is not dispensing any water the issue may be the inlet valve may no longer be working correctly. This could be the faulty valve or no voltage is going through it cause it to not work properly. You may check the wiring for this one. The other is that the ice may have frozen.
The ice dispenser may not be dispensing ice because of a buildup of ice in the screw like piece in the dispenser. This prevents movement thus preventing ice to be dispensed. This may be caused by the freezer not cool enough since some ice will melt and eventually will turn to ice again but build up on the screws.
Posted on Jun 23, 2009
I have a GE Profile Arctica Fridge. The temperature in the Freezer has dropped to 34 degrees and the Fridge has dropped to 40. The fridge is running and is blowing air in the freezer, but not really...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE Profile Arctica Stainless Steel Top...
GE Arctica Refrifgerator- Not cooling
its either the ptc overload on the units compressor is bad and is easily replaced by unplugging the old and replacing with a new replacement,the only other thing it may be is the cold control for setting the temp of the freezer/refrigerator,but normally these don't go out
May 15, 2010 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Power is on but no control indicators are visible and the letters HRS are flashing inside one of the indicators inside the door. The refrigerator model is a pss26ng GE Profile Arctica
Unplug this refrig from the wall, let sit for one hour, then plug back in, if it starts then you may have a start device on compressor that is bad, more than likely it won't, normally the HRS means there is a "main board" problem. Main board is located on rear of refrig.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
Top Freezer Not Cooling...Fan Running...everything thawed :(
Check the thermostat in the refrigerator and make sure it's not accidently turned to the defrost mode
Jan 08, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica
The main PCB at the back of the appliance has failed
Nov 12, 2007 | GE PSS25NGM Side by Side Refrigerator
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
177 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
