Question about Kirby Generation 3 Bagged Upright Vacuum
The auto forward/reverse when vacuming not working. Have to push & pull very hard...it used to glide very easily.
  • 3 Answers
I would guess the belt that powers the drive unit has broken. It needs to be replaced.
Posted on Oct 02, 2009
Testimonial: "It appears it may be working.It only is difficult when the suction(brush)head is lowered to the carpet.How do change the belt..if I have to? "
ComThe vacume handle is very difficult to get out of the upright position. It use to take just a gentle tap on the front of the vacume to release the handle. Now I have to stomp on the vacume front to get...
Sorry to hear you're having difficulties with your DC14. The cleaner should recline easily into the vacuuming position when one foot is placed on the cleaner head, and the handle is lowered. If it's not doing this, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
Dyson DC17 Found the clog-how do I unclog it?
poke it out with a screwdriver this will dislodge the hair it might take a while to get it all out
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Need to open the electrolux vacum
The locking key on the side of the vac has a tightening wedge on it so it doesn't slide easily. Spray the entire key top and bottom with WD40 or similar. Grasp at the bag door area with vise grips and pull the key straight forward.
If the key will not slide, you will need to take a large flat bladed screwdriver and lay the blade flat at 90 degrees against the back end of the key. then strike the side driving the key forward toward the bag chamber door. Do not twist.
Aug 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
Mar 19, 2009 | Bissell Upright Vacuum - The Pet Hair...
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
G2000 Kirby HELP
I'm not familiar with this type of vacuum, but if it's like most kirby's the powerhead gets all its motion off the tapered spindle underneath the powerhead. IF the belt is installed backwards on this spindle then all motions are reversed. there should be an arrow stamped into the blower housing. the belt should be installed so it is nearest to the arrow in the direction of the arrow on the housing.
Aug 22, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Kirby Generation 3 Bagged Upright Vacuum Logo
138 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
