Question about Motorola Mobility RAZR V3m Cellular Phone
Battery will not charge.
The screen will state the battery is charging but the battery isn't receiving any charge. I removed and replaced the battery to no effect. The phone is only 2 months old and has no other ploblems.
  • vax31j Dec 18, 2007
    Same problem! The phone dies within seconds after the charger is removed. Used 2 different chargers and I bought a new battery; all with the same results.
  • Anonymous Dec 21, 2007
    My phone will say charging battery. I will have the phone plugged into the charger for hours but it will still say low battery and after I unplug the charger the phone dies
  • 55 Answers
Inspect your connectors on the charger and phone side.
Dirt or corrosion can cause a poor electrical connection.
If you do see some material that should not be there, try using an old clean dry tooth brush to clean it out.
Do not use water or you will damage it more.
If you need to use any liquid to aid the cleaning, I suggest Isopropal Alcohol.
Posted on Apr 25, 2008
  • 38 Answers
I think the phone malfunctioned or need new battery. If problem presist call the company and they'll send you a new one and you replace it with the new one.
Posted on Dec 22, 2007
Tip
Determining the State of Charge of Your Nuvi 350 Batttery
To view the state of charge of the battery in your Nuvi 350 hold your finger over the Time Display in the upper right corner on your Menu Screen for 8 to 10 seconds This will put you into an Information Mode the first screen of which starts with:
SWVer 5.10 nuvi1x2GB_2CS
Touch Next 4 times and you get:
Battery Test Page
Batt State Ok Cap
VBattery 4.07
BattCap 93
Bat Chrg1mA -198
BatChrg mAhr 1207
Chrg Cycles 3
on Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
Satellite M205 S4804 Problem
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Isn't starting. battery isn't getting a charge. bike starts once the battery is charged
Your battery MOST LIKELY has lost some of the battery cells, which will cause it to get a partial charge which will show it as a FULL charge when in fact it isn't getting a full charge. You should try taking it to get the battery tested and they can tell you if it needs to be replaced. I would guess they are going to replace it for you. A new battery should run around $90 for a motorcycle. Let me know if this helps you out. Jeff from fixya
Jun 11, 2011 | 2007 Hyosung GT650R TTC
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
Some manufacturers put some chip on their battery so it can be identified by their charger. If you use a generic battery often, it will not charge or work properly. LG does this with their phone batteries! So you have to use another charger to charge them.
Jul 07, 2017 | Makita Drills
When charging my Garmin 265WT, is the screen supposed to show when the battery is fully charged? e.g. charging complete
While it's charging it doesn't show the battery indicator. When the charger is plugged out it shows the battery state on the screen that shows WHERE TO and VIEW MAP
Feb 25, 2011 | Garmin Nuvi 265W GPS Receiver
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
Motorola Mobility RAZR V3m Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
