Question about Casio Exilim EX-S500 Digital Camera
Small crescent line in the corner of my casio
Small crescent line in the corner of my casio camera l
How do i switch to video?
On the back of the camera, at the top-right corner, there is a multi-function button. The center of it has an icon that looks like a video camera. Press that button.
See pp 59 of http://support.casio.com/pdf/001/EXFH100_M29_FB_100311_E.pdf for an example (you might need a slightly different manual - You didn't give the model number of the camera).
Mar 03, 2011 | Casio EXILIM Digital Camera
I dropped my GE A1035 camera, where can I find the service center here in Manila ?
The nearest service centre seems to be in :
GE (General Electric) Philippines, Inc.
8th and 9th floors,
Net Cube Building
30th Street corner
3rd Avenue
Crescent Park West
Bonifacio Global City
Taguig City 1634, Philippines
Thank You.
Feb 10, 2011 | Cameras
When I view my photos they have tiny horizontal white lines on them (and they also print with these lines on as well) ????
hi there 2 reason is here.
1. LCD damaged. In print out photos must be clear.
2. If lens have small tiny screch lines then printed
photos also come with that lines. Thanks.
Mar 27, 2010 | Casio QV-R51 Digital Camera
Remove PW steering hose
The tools required are :-
  • Large crescent wrench
  • Small crescent wrench
  • Drain pan
  • Shop towel
A Generic Procedure ( This example is for Other brand but might help you, if needed ) is :-
Step 1
The power steering pump is located on the right fire wall of your vehicle. Place the drain pan directly under the power steering pump and use your small crescent wrench to open the drain plug by turning it counterclockwise until removed. Take care that the car has had time to cool so that you do not burn yourself with the hot fluid. Allow the fluid to drain until it is slowly dripping.
Step 2
Use your large crescent wrench to turn the power steering line nut counterclockwise until it is completely loose. The line will not come off at this point.
Step 3
Use your large crescent wrench to turn the bottom power steering line nut counterclockwise until free. Pull slightly upward and free the line from its seat. Both ends of the line will now come free and the line is removed.
Step 4
To replace the line, use the same procedure in reverse. Put the drain plug back in and add the appropriate amount of fluid.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 13, 2010 | 1993 Nissan Maxima
My new stainless overmount sink will not lay flat on new counter
Probable not warped, more likely the corner tab is bent. If it is just the corner place a rag over the corner, then using a crescent wrench tighten it on the corner using the rag to protect it from scratches and lightly bend it back. Do this incrementally. If it is more then just the tab ( 6" or more from the corner), remove the sink, place it on the floor, (upside down), place a 2x4 under the offending corner and press down on the sink. Again do this in small steps. Just use a straight edge to know when you have moved it enough.
Before you do any of this make sure your counter top is level!
May 14, 2009 | Hand Tools
Camera fell on the floor (carpet) and now the
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Casio Exilim EX-Z750 Digital Camera
My pictures come out too small when downloaded!!
Instead of going to print size, you need to head to the quality tab of your camera. Here you will find the option for 640 x 480. This size is only good though for email quality. If you want a higher quality for printing images, you need to move that resolution up.
TIP: I myself have a casio camera and i take all my pictures at the highest availible quality. You can always reduce the file size on your computer, but you can never add quality. While it may take more space on my card, it is like the old saying about dressing warmly... you can always peel layers off....
Aug 24, 2008 | Casio Exilim Card EX-S100 Digital Camera
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Aug 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio ex-s500
they are on the front side once you remove the cover diconnect the ribbon cables and look at the bottom right hand corner and there is one of your clips. the other one is caddy corner to it top left of the lens. I fix them also.
Feb 08, 2008 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
16 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
