Question about GE Refrigerators
HOTPOINT/GE hss25GFPHWW first the water stopped running, then no ice, now it is not running at all. Water to the filter, lights on
  • GE Master
  • 4,655 Answers
If your refrigerator is not working at all then this is a common problem related to the mother control board located on the rear of your refrigerator. Many times you can unplug the refrigerator and remove the control board and examine both sides for burn marks or signs of heat damage. The part number for *********** board is WR55X10942 Surge suppressors are helpful because electrical surge is one of the causes for failure. Have a look with power unplugged and let me know what you find. Thanks, Sea Breeze
Posted on Sep 26, 2009
  • John Tripp
    John Tripp Sep 26, 2009
    Now if we are talking of the dispenser control that may change everything. But if the refrigerator is affected then we will go with the board problem. Here is a photo of the control board.
    If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
    appliancepartsse@yahoo.com
    SEA BREEZE TIP'S
    http://servicepartstec.blogspot.com/
    You can find the board or other parts at the link above.
How to get alarm to stop blinking after replacing water filter
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Dec 03, 2015 | Fagor FQ9925XUS
Hello, my ice maker is not producing ice, also, there is no water flow for cold water. I checked the water connection, it is charged. Can you recommend a solution pls.? My fridge is a HotPoint...
What about water filter? Is clogged? It is located in fresh food side in back righthand upper corner. also the holder me be bad. You can bypass the filter assembly By going in back of fridge. Hook incoming water to water valve to test. I hope this helps.
Aug 29, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Hotpoint side by side.No ice is produced.Switch is on.has new water filter,freezer cold.
is freezer colder than 15 deg / is light blinking on ice mker or is it solid . filter does not cause no isc problem . mm
Oct 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side Hotpoint model #HSS251FMD.The water dispenser stopped. Replaced filter and now no water or ice.
sounds like the water inlet valve is not letting the water come in. need to check and perhaps replace this valve. hope this helps.
Oct 13, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
I have a hotpoint refrigerator hss25gfpjww...symptoms I was having are ghost noises and water not working...the ice does work. I have replaced the water filter and the motherboard and the ghost noises have...
I have a GE. Same 2 problems. I still have the ghost, but I fixed the water. There is a coiled up tubing inside the refrigerator behind the vegetable drawer. It was frozen. I took the drawer out and turned the rerigerator off and left the door open for about 4 hours while we watched tv. Tried to run the water with no success. Just about to give up when all of a sudden water flowed. It happened 1 more time, but not for about 6 months now.
What's the ghost noise solution?
Jan 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
