Question about Garmin Forerunner 305 GPS Receiver
My Garmin 305 wont record calories when I'm in the Gym. I select the "Other" sport mode, the little guy skiing, and It doesn't recored or even register calories? It records during my Jog sessions while using GPS but not during my indoor workouts? Anyone have any clues?
  • jerrywriter Dec 27, 2007
    Same problem...maybe it only records calories in GPS mode???
  • suej8041 Jul 09, 2008
    Mine used to record calories in the "other" mode, and now it doesn't.  It could possibly changed after an update was downloaded??
The 305 uses distance to calculate calories. They sell a "foot pod" that you can use indoors, and that will count your calories by calculating the distance you have traveled. The problem however, is that using distance to calculate calories is so inaccurate! The calorie count that the 305 provides is almost always WAY too high. Other heart rate monitors use heart rate to calculate calories burned, and it is a much more accurate measure. My garmin thinks i burned 700 calories an hour today while i was snowboarding, and, while that would be nice, there is NO way it's true!!
Posted on Dec 30, 2008
I have similar problem, looking online now to see if there is a fix or whether it's just when GPS mode is on. Will drop a note to Garmin or call, and hope to get an answer.
Posted on Aug 19, 2008
My gramin forrunner 305 sudenly doesn´t turn on what should I do
Use reset procedure as indicated in Garmin book or support center (hold reset plus mode buttons for 10 sec on charger, then wait 10 other secs, then start again, all this connected to PC.
Aug 12, 2010 | Garmin Forerunner 305 GPS Receiver
I seem to have lost the alarm (BEEP) on my Garmin 305.
It's a known problem. The little speakers inside get corroded and gradually get quieter and quieter. If you are still within warranty, then send it back to Garmin for a fix. If not, there isn't a home-user fix for this problem, so you'll have to decide if it's worth the $$ to get it fixed. Personally, I decided to get mine fixed.
Jul 26, 2010 | Heartbeat Garmin Forerunner 305 Gps...
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
May 16, 2009 | Heartbeat Garmin Forerunner 305 Gps...
Garmin Forerunner 305 miscalculating ascent and calories
Firstly, the ascent and descent are only approximate, and can be very approximate! This is because it's using GPS to calculate your height above sea level when GPS is really only accurate for position Lat and Long. When calculating height, a very, very small error can lead to a large variation in actual height. You should never use a GPS for height if needed for navigation (ie climbing walking etc) If you need accuaracy you will need to get a barometric altimeter.v
As for calories, I think you have identified your problem, it's calculating calories on running not cycling. Not sure what the answer is as I don't know what software you are using but if you are using Garmin TC, bin it and use SportTracks. Takes a bit of getting used to but to really get the best out of your 305 this is excellent software and it's free. Any anomolies like your calorie issue/wrong category import can be changed manually plus a whole host of other stuff. Garmin doesn't even let you edit activities - crazy.
Apr 04, 2009 | Garmin Forerunner 305 Personal Trainer...
Garmin 305 is off and wont come back on.
You have to soft reset it first, and if not solving, then try hard reset.
Soft reset : hold lap/reset with mode key for some seconds
Hard reset : hols start and mode, then pulse on lap/reset.
after soft reset hold on/off for up to ten seconds before it starts.
after hard reset all data are lost
Mar 15, 2009 | Garmin Edge 305 GPS Receiver
How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Mobile XT not excepting my GPS Receiver
Garmin will work with ANY windows mobile device with built in GPS and or a bluetooth receiver. But you have to have the correct software there are 2 versions both will install but only one will work with your model phone for older model phones use version 4.10 or lower for newer model phones use version 5.0 or higher.
Let windows manage your GPS ports do not try to set it manually. If you have a GPS fix option...go out side where you can get a satellite fix easily...launch your GPS fix program...thenlaunch Garmin. It should connect and you will have to do this only once. I know from experience and I've use this on a T-Mobile Dash with a bluetooh adapter with no issues. I'd try a different receiver preferably any Pharos GPS receiver.
Dec 31, 2007 | Palm Treo 700w Smartphone
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
745 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
