Question about E-Machines eMachines Desktop PC
I need a 12 v power lead for e mahine pc, do you know any place i can get one, i have tried lots of places already, please help me, thank you.
  • 63 Answers
Mwave.com
Posted on Sep 27, 2009
No network card present on Foxconn A74ML-K. I have reset the bios and cmos.
Hi clordjr,
Try to remove your LAN Card from the PC.
Afterwards, clean the gold plated conductor fins with pencil eraser.
Then, place it back properly to the PCI Slot.
Restart your PC and check if the LAN Card is already detected by the system.
If there is a need for re-installing the driver of the LAN Card, please do so.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 31, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
Jun 23, 2011 | Schiller Welch Allyn Cardiovit At 2...
I own a 1985 honda elite 150. I tried to started with no success. I was told that it needed a new battery which I replaced. The battery is fully charged. The light beam is bright when i turn the key on the...
Buy you a $10 volt ohm meter. Set it on DC Volts 20 volt scale or that range. Find starter solenoid place leads on small wire connectors have someone try and crank when they do you should have 12 V. If you do have the voltage you may have bad solenoid contacts. Place meter test leads on large wire contacts if you have 12 v there when the person tries to start you have open contacts on solenoid. If you do not have 12 volts on meter when person tries to start place one lead on one of the large wire post and the other on neg. Terminal on battery if you now get 12 v you probably have a bad starter.
Jul 23, 2017 | Honda CG 150 Titan KS Motorcycles
Is a ih 460 positive ground
This one is easy to figure out. You can use a voltmeter or a 12 volt light bulb. Please one lead (wire) to the frame of the tractor and the other lead on a battery terminal. If the lamp lights when you place the lead on the POSITIVE terminal (or the meter reads 12 volts), it is a Negative grounded system. If the Lamp lights when you place the lead on the NEGATIVE terminal, it is a POSITIVE ground system.
Oct 09, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
HELLO- I NEED NEW POWER CORDS TO CONNECT MY XEROX DOC 12 TO THE COMPUTER TOWER WHERE CAN I GET AFFORDABLE USED REPLACEMENT CORDS? THANK YOU- KRIS BOLINE
if cords are the power cable, then go to maplins or any place that has electrical hardware, 13 amp kettle lead is what is needed
Sep 27, 2010 | Xerox DocuColor 12 Printer
My car cigarette lighter is not working. I have a 98 plymouth breeze and I've tried checking the fuses and its still not working. My radio and everything else works just fine do i need to replace the...
If all the fuses have been checked and are working as you say, try doing a voltage check on the cigarette lighter receptacle itself. If you set your DVOM (Digital Volt/Ohm) meter to DC volts, you should be able to measure 12 volts (+- 2) at the receptacle by placing the red lead to the positive end of the receptacle, which is the little button on the very back of the barrel, and the negative end, which is the outer chrome housing. (Of course, some vehicles require the ignition key to be placed to Acc or Run, but I'm sure you already know how your car is configured.)
If there is no voltage there, the fault may be in the wiring itself, behind the cigarette lighter. Get behind it to make sure that the positive lead hasn't been pulled out or is corroded for some reason.
If all is well with the receptacle and you want to be able to actually USE the cigarette lighter in it, you may want to consider purchasing a replacement lighter. You can find a lot of those in the "Help" line of parts at your local auto parts store.
I hope this helps! Let me know if you have any further questions. :)
-Jason
Jun 18, 2010 | 1997 Plymouth Breeze
VGN-S1XP laptop will not power up despite resetting it.
have you tried taking the battery out and powering up without it in, if you get no power at all your charger is more than likely at fault. if you can power up then it is the battery or connections that are at fault
Oct 26, 2009 | Sony Computers & Internet
Dead
All you have to do is place the watch in direct sunlight for about 12-24 hours and it will be working perfectly again in no time at all. Make sure the light is shining directly onto the watch's face as that is what needs to absorb the solar power. You can just place it in a window sill that gets a lot of sunlight and let it charge all day.
If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
Jan 08, 2009 | Silhouette Citizen Eco-Drive Watch
Samsung s1050
rechargible batterys need to be charged before used on anything
Apr 30, 2008 | Samsung Digimax S500 Digital Camera
How to instal my deck to a amp and sub
you would need rca cables, power wire, ground wire, and remote wire. it is easiest to just go to your local best buy or circuit city stores and buy the whole set in one package. rca's lead from your decks rca output jacks to your amp, remote wire leads from your decks wiring (blue remote wire that leads to your deck itself to give it remote) or any 12 volt source like where your fuses are located and it runs to the amp also, your power wire will lead from your battery to your amp, and your ground will need a good place somewhere in your car and be bolted or screwed to the frame of your car. this is how to intall your deck to your amp. i assume that you already know that wires will have to be under your carpet or kickboards and such however you run them. i think this covers the basics and i hope i have answered your question right, good luck
Oct 06, 2006 | Alpine CDA-7892 CD Player
E-Machines eMachines Desktop PC Logo
13 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
