Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Saw will start will chock out, when chock is
Saw will start will choke out, when choke is pushed in, it stops. Homelite 45CC I have replace all carborator gaskets and mandifold, new fuel lines and filter. When it does idle and you mash throdle it dies.
  • 148 Answers
Your symptoms indicate a lean condition. Check to be sure the muffler and/or spark arrestor are open and unobstructed. If all the parts are installed properly and your mixture screws are between 1.5 and 2 complete turns OUT, the saw may possibly have leaking crankshaft seals. The saw would need a pressure/vaccuum test at a repair shop to verify this.
Posted on Sep 26, 2009
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
How do you chage a choke knob on a poular chain saw
If the knob is attached to a cable you will need to replace the entire cable which comes with the knob attached. You can just follow the cable and determine how to route the new one and attach it the same as now to the carb.
Jun 17, 2014 | Poulan Pro 260 Chain Saw Av Springs,...
My 46cc Homelite will start & idle with the choke on, as soon as I push in the choke it reves up by itself then cuts off
This is fuel starvation, start by removing and replacing the fuel filter in the fuel tank, check the fuel hose up to the carb foe signs of leakage, replace hose if required.
Aug 21, 2011 | Homelite FactoryReconditioned ZR10522...
Hard starting on a Makita line trimmer? How do I solve this issue?
Try pushing the primer 8-10 times hold the throttle wide open and turn choke too full.when it starts it will probably quit turn choke to halfway and start again.should stay running.If that don,t work carb needs to be rebuilt or replaced.
Nov 29, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Had difficulty starting chainsaw DCS4610 for the first time. Think it was flooded. Problem now it wont idle.
Is this a new saw? If yes return it or at least ask for a recommended repair facility. Your saw is actually a Dolmar (owned by Makita) and a fine saw. In order to meet EPA requirements they are set very lean (many 5100s seize with factory settings). To protect your investment and not invalidate your warranty I recommend it be adjusted by the
professional recommended by the merchant where you purchased it or one recommended by Makita.
The starting procedure is probably similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
Most new owners miss opening the choke after it tries to start or do not hear the pop when it does and flood the saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
New Homelite 16" chain saw is difficult to impossible to start.
Read and follow the start procedure in the manual, most say to open the choke once the saw attempts to start. Most operators miss this or do not hear the cough and flood the saw. Your manual is probably similar, if not successful with the following maybe time to return it. One thing that might impact starting, what is your elevation? Your saw was setup at near sea level, if you 4000' it may need an adjustment. The store where purchased will probably recommend someone if asked.
Start Procedure
Cold:
Warm:
Lou
Apr 02, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Lost my manual. Forgot how to start the darn thing?
Might it be beneficial to include a model number where the answerer cannot see the item in question? The embedded numbers (heading) are often someone elses best guess.
Start Procedure
Cold:
Warm:
Lou
Mar 24, 2010 | Homelite ZR10926 16 Chain Saw
Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Aug 29, 2009 | Garden
Forgot how to start it
Put the choke on, and if it has a primer bulb, push 3 times, then crank it.
Jim
May 31, 2009 | Homelite ZR10926 16 Chain Saw
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
222 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
