Need wireing help
Removed washer inlet valve to clean screens...didnt pay attention to where wires attached, in what order....help
  • daniel  hendrickson
    daniel hendrickson May 11, 2010
    whats the model # and make of washer ?
    President:
  • 1,922 Answers
If you have 2 sets of wires 4 connections just hook up the 2 to one solenoid and set to HOT water or cold water and see which water valve solenoid operates, if wrong just reverse the 2 pairs
Posted on Sep 26, 2009
What does F20 on the washer mean?
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Im trying to replace the fill valve on a Kenmore washer model # 110.28812790 serial # CG4186264. I am having trouble getting the back off to get to the valve. Do you know how to do this? Thanks
I just replaced the fill valve on my front load Kenmore Elite HE4T it is actually a very easy fix.
1. Turn off the hot/cold water supply to the washer. 2. Remove the top cover of the washer by removing the three screws located at the top of the back panel. 3. Lift up the rear of the top cover about 1" and pull toward the rear of the washer. The top cover should pop off. 4. Remove the water supply hoses if they are not marked "H" and "C" mark them so that when you reconnect they are not reversed. 5. On the back - left side of the inlet valve is a spring clamp holding the black water supply hose to the inlet valve. Using a pair of pliers loosen and slide the clamp an inch away from the hose end. 6. Using your fingers and a flat tip screwdriver pry the inlet hose off of the inlet valve. 7. Place the new valve near the defective valve and remove the wires attached to the "H" and "C" inlet relays (they are two square blocks with two wire terminals on each). As you remove each wire attach it to the corresponding terminal on the replacement valve. I found it was best to pry off the plastic connectors with a screwdriver from the top while pulling them off. 8. There is one screw holding the valve to the back panel of the washer, remove it and remove the defective valve. 9. Attach the water black water supply hose to the new valve and slide the spring clamp back over the nipple of the inlet valve making sure it is near the end of the hose, but not over the edge. 10. Install the new valve by lining up the single screw hole and reinstalling the screw. 11. Reconnect the "H" and "C" supply hose paying attention that the "H" is connected to the inside and the "C" is connected to the outside inlet. 12. Turn on the water supply and run the washer through a fill cycle checking for leaks at the supply hose connections and the black hose at the outlet of the fill valve. 13. If everything is still dry reinstall the top cover by putting it in place and sliding it forward. Replace the three screws that hold the top panel.
The entire repair should take you less than 30 minutes. If you have enough room between the back of the washer and the wall you really don't even need to move the washer.
Jul 04, 2010 | Washing Machines
Kenmore 80 Series- Washer does not fill up with water before it starts washing.
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Nov 07, 2009 | Kenmore Washing Machines
My washer is not filling with water in order to begin the washing process
HI. First you will need to check the water fill faucets to make sure that they are turned all the way on.If the faucets are on, then move on to the hoses. Check the hoses for kinks. Make sure the hoses are straight, and not curved. If all checks out Ok here, i would advise to move on to the filter screens.
The hot and cold water from your home is connect to the water inlet valve on the back of the washer. In each end of the water supply hoses there may be a filter screen to catch debris and prevent it from damaging the washer. The water inlet valve also has filter screens. If the filter screens become clogged, the result is low water pressure, no water or the wrong water temperature,as well. The water inlet valve can be identified by the water hoses connecting to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting adequate water pressure and to clear any debris from the line.
Inspect the filter screens on both of the hoses and the inlet valve for debris build up. If you find any debris, clean it out. The screens in the inlet valve are not removable so use caution to avoid damaging them.
If you are getting good water pressure and you find no build up of debris, then the inlet valve itself may be faulty.
TESTING PROCEDURE FOR THE WATER VALVE ASSEMBLY
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first
NOTE:-(The water inlet valve can be identified by the water hoses connected to it at the back of the washer.)
Oct 23, 2009 | Whirlpool Washing Machines
The washer won't fill up when it is on rinse cycle...what do I need to do?
I would check for a cold water supply problem, since it requires cold water for the rinse. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust and debris. Pay particular attention to the cold water side. The solenoids can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need replaced. I'll attach a photo for reference. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Washing Machines
3 hours wash cycle
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports. Make sure they are clear of rust or debris. Based on your description, pay particular attention to the hot water side. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Sep 04, 2009 | KitchenAid KAWS750L Top Load Washer
Washer has been working fine for sevral years.I started a load when it went into rinse cycle it stopped and will not run at all. this is a Kenmore extra large capacity model no. 110.14102300
If no water entered the machine at the rinse cycle, then I would check for a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clear of rust or debris. Pay particular attention to the cold water side. Next, check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid. I will attach a photo for reference. Check this and if you need additional assistance let me know. I am working with limited info. For instance, can you advance the cycle manually and make the machine operate? Sorry for your trouble and I hope this helped. Best wishes.
Sep 02, 2009 | Kenmore 22422 Top Load Washer
Does not take in water from faucet
Water solenoid valve. Try using hot only or cold only. If either one works, then the one that doesn't work needs a new water solenoid valve
Sep 01, 2009 | Kenmore 24032\24036 Top Load Washer
Turned on machine , does not fill with water on any setting... water knob is on... light comes on...it will spin but not fill or wash. Please help!
Check the water inlet valve. Remove the water supply hoses and check the small screens located inside the outlets on the water valve/ Make sure they are clear of rust of debris. Next, the solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Aug 27, 2009 | Washing Machines
Hot and cold water inlet valve was replaced but no
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 08, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
