Question about Mitsubishi VS-45607 45" Rear Projection Television
I have a mitsubishi vs50604. it is about 10 years old. when we attempt to power the tv up, the power light transitly shows green then clicks off. we have attempted to power the unit using the remote control and also by pressing thepower button on the unit. we have unplugged the unit, and then reattempted to power the unit with the same results. the tv is connected to a dish satellite tv system. we rebooted the dish reciever, however the mitusibisi tv still will not power on.
  • Mitsubishi Master
  • 19,396 Answers
The TV is on protect mode.
You already did the first two steps of troubleshooting:
  • Leaving the TV power cord unplugged for some times, at least one hour or so.
  • Ensuring that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that did not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
You are in situation 2 , then the TV is faulty.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you are a technician and you want to DIY, start testing the PSU , convergence board and ballast. If problem is not there , then get the service manual to test digital board and optical group.
you can find service manual here:MITSUBISHI VS-45603 VS-50603 VS-60603 VS-50604 SERVICE MANUAL .
Posted on Sep 26, 2009
Hdtv flashing green light for timer tv wont turn on
If the TV is a few years old the flashing green light means the bulb need to be replaced. That's why the TV will not show a picture. Check your owners manual on how to replace.
Mar 20, 2013 | Mitsubishi LT55164 Unisen Medallion 55...
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
My mitsubishi Model # WD-60737. It is lesss than a year old. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the wall for an hour....
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Jan 11, 2011 | Mitsubishi WD-60737 60 in. HDTV
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Try the ballast that gives power to the lamp,I have the same problem,got a lamp for $109.00 at discount-merchant,thisa is my second problem with this tv in about 3 years,sucks.
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi vs45607 dead
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Jan 02, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi will not turn on
If the green light flashes, thats an indication that there is a problem in the sweep power supply or the horizontal drive circuit. Its not a problem a layman or unexperienced person should attempt to repair unless you know about electronic circuits and how they work.
Sep 22, 2006 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
